Old 07-02-10, 08:23 PM   #1
pencil shavings
Default How to remove the front wheel without the bike falling over thread
Anyone got any tips without buying a front stand? Ive got a rear stand, but not a front one and I need to get the front wheel off so I can get the tyre changed.
thanks peeps
Old 07-02-10, 08:29 PM   #2
Default Re: How to remove the front wheel without the bike falling over thread
Car jack & a piece of plywood under the engine, with the rear stand in position.
Just make sure it's secure
Old 07-02-10, 08:31 PM   #3
fizzwheel
fizzwheel's Avatar
When I did my fork seals, we
1. Put the bike on a rear paddock stand
2. Stacked up some bricks to rest underneath the engine ( watch the exhaust when you do this and put some wood between the actual engine and the bricks, and be bl**dy careful )
3. The we used a decent good strong piece of rope and looped it through the yokes and strung the rope through the rafters in my dads garage and then pulled it up off the ground that way. If you're going to do this, make sure the rafters will take the weight of the bike first.
That gave us enough room to get the front wheel out and also take the forks out to.
I have to say its not ideal, and if you can borrow a front paddock stand from somebody locally that would be probably better, but it did work...
Old 07-02-10, 08:34 PM   #4
Or better still buy an ABBA stand, makes everything less fraught and less likely to fall over.
If you have an ABBA stand you can just lift the engine up by whatever means which tips the weight rearwards, as it pivots around the swingarm pivot
Old 07-02-10, 08:45 PM   #5
I don't like using rear stand. You have only 2 points of contact.
Put car jack under engine, jack bike over on its side, weight is held across 3 points (sidestand, rear wheel, engine) and it is very solid.
Old 07-02-10, 08:46 PM   #6
Bunks
[QUOTE=fizzwheel;2174324]
QUOTE]
Make sure you do tie the bike to the rafters otherwise it could fall over and dent the tank causing £130 of damage. Not that that happened to me
If you have crash bungs I tied the rope to them and put it over the rafters. The next time I wanted to jack the front up, I though it'll be fine!
Old 07-02-10, 08:59 PM   #7
pencil shavings
I like this idea
unfortunatly I dont have a garage so it will be done outside so I dont have any rafters to suport the weight
Old 07-02-10, 09:03 PM   #8
fastdruid
fastdruid's Avatar
That was how I did my original frontend swap.
Druid
Old 07-02-10, 09:11 PM   #9
Originally Posted by pencil shavings View Post
I like this idea
I never mentioned rafters?
Old 07-02-10, 09:29 PM   #10
Ratty
Ratty's Avatar
Use a rear padock stand, weight the rear seat, trolley jack under the engine with a piece of wood for protection. If you leaving the bike for any length of time, put your axle back through and an axle stand under it. When I came back to mine the trolly jack had lowered off !!!
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
How do you remove the front wheel without a paddock stand? pointy SV Talk, Tuning & Tweaking 5 30-10-07 05:41 PM
the falling off thread :( kwak zzr Bikes - Talk & Issues 58 24-09-07 01:14 PM
How D'you remove wheel bearings... Stormspiel SV Talk, Tuning & Tweaking 9 22-11-05 09:21 PM
Humming sound from front of bike, wheel bearing? trailer_parks SV Talk, Tuning & Tweaking 7 09-12-04 01:30 PM
