Old 08-02-10, 01:43 PM   #1
James SV
Default Dodgy speedo drive?
Hi there, i own an 03 sv650s in silver,
Most of the time my speedo does not work and sits at 0 but occasionaly it starts to work as it should for a short period of time.
Could this be due to loose connections/dirt buildup or am i in need of a new speedo drive?
Many thanks,
James
Old 08-02-10, 01:50 PM   #2
Sosha
Default Re: Dodgy speedo drive?
Wop front wheel off, check rotor. chances are the ears'll be snapped off or it'll come out in pieces. New one's about 18quid. Get the right model or you'll be seeing double.
Old 08-02-10, 02:36 PM   #3
Smudge
Old 08-02-10, 11:04 PM   #4
thefallenangel
mogs had this problem on the severn circuit rideout last year, defo new rotor.
Old 08-02-10, 11:30 PM   #5
madnlooney
i had exact same problem on my k3. It was the rotor, would work then sit at 0, wiggle cable on from wheel and worked a little. The rotor was knackered when i took from wheel off. Rotor has 4 'ears'
Old 09-02-10, 07:56 AM   #6
STRAMASHER
STRAMASHER's Avatar
Superglue the bits of the rotor back on and carefully reassemble.
Hello speedo! No more speeding paranoia!
Old 09-02-10, 11:51 AM   #7
Smudge
like it bodgetastic whats the rotor made of any how?
Old 09-02-10, 12:01 PM   #8
Warthog
I had same problem, rotor was mashed, but actually upon fitting of a new rotor it turned out not to be the whole problem, and that the lower cable and sensor part was dodgy on mine. I got and fitted a replacement and have had no more problems since. Search for my thread about it if you want more info.
Old 09-02-10, 12:04 PM   #9
Smudge
i havent had a problem since sorting my own tyres out it just down to dodgey garage assembly
Please help speedo drive ssmith87 SV Talk, Tuning & Tweaking 4 12-09-09 05:59 PM
speedo drive ging6996 Stuff Wanted 0 28-04-09 05:05 PM
speedo drive baldwone Bikes - Talk & Issues 5 12-03-09 11:03 PM
Help! Need a speedo drive richwill68 Stuff Wanted 6 27-03-08 03:09 PM
Speedo drive goody SV Talk, Tuning & Tweaking 0 13-08-07 07:30 PM
