The exhaust and plugs suggest that the engine in running a little rich, since I changed the exhaust to a fuel slip-on can (bit sooty). I get around 130miles on a tank and it seems to run OK (sounds great), before the exhaust change was getting 120mile per tank.
Various places suggest that if I was to put a K&N filter in it would run leaner (more air). So do I: a) Leave it alone, its running all right don't f*** around with it. b) Stick a better flow air filter in, it'll lean it up a bit. Might be all that's needed. c) Change the air filter and adjust the idle mixture using a colour tune plug. d) Re-map the carbs (yes its a curvy) and enter a whole new world of hassle. Don't care about extra power (cause I won't get any), would just like the fuel mixture to be right and not soot the plugs up (although this hasn't caused any miss fires etc). Thoughts? |
I'd try with a race filter personally (BMC are the recommended ones IIRC), but you could always mess around with the jetting (or leave it alone!)
I have the same thing, bike rides lovely but plugs suggest it's running very rich - slightly less options on the pointy though...
You could start by checking your choke plungers and cables as these stick and cause rich running.
#4 | |
![]() Wahooo 100 posts ![]() |
New bike running rich, please help | nicollow | SV Talk, Tuning & Tweaking | 24 | 12-12-09 07:38 PM |
Running lean / rich | sauluk | SV Talk, Tuning & Tweaking | 10 | 15-05-09 02:06 PM |
Running rich | AndyBrad | SV Talk, Tuning & Tweaking | 1 | 14-09-08 12:41 PM |
im sure its running rich | John 675 | SV Talk, Tuning & Tweaking | 11 | 03-10-07 01:21 PM |
running rich? | 01 sv650s | SV Talk, Tuning & Tweaking | 17 | 10-02-07 10:41 PM |
