Old 01-03-10, 11:27 PM   #1
5hort5
Default Weeping rear brake bleed nipple.
Title says it all really, apart from being broken down on the slip road of J22 M6 I was on a test flight and noticed a couple of things, the first being a nice pool of oil collecting under the bike, this is simple it's the clutch cover that every time I try and fix I make it worse. The second was a very small leak and from the rear brake bleed nipple.
Now what to do about it??? It's torqued to the 7.5nm but should I:
  • Tighten it more (till it snaps lol)
  • Replace the nipple
  • Put some PTFE tape (or brake equivalent) on it and put it back in
  • Other
Many thanks for the input
5hort5 is offline   Reply With Quote
Old 02-03-10, 01:25 AM   #2
rotax81
Default Re: Weeping rear break bleed nipple
try releasing it a few times then tighten it to torque, it should be ok.
if not get a new one.
Old 02-03-10, 08:49 AM   #3
PTFE tape will not work. Bleed nipples seal on the cone on the end, not the threads.
I'd agree with rotax.
Old 02-03-10, 09:32 AM   #4
Spanner Man
Good morning all.
If you have any corrosion on the tip of the bleed nipple you can get a leak. Take it out, & wire brush the tip (sounds painful). The see how it goes.
It'll help if you have an M7x1mm bolt with some PTFE tape around it to insert into the nipple threads to stop it leaking while you do the above.
Cheers.
Spanner Man
Old 02-03-10, 09:34 AM   #5
Or just hang something off the lever, you will lose a little bit of fluid but will close the transfer port so it doesn't dump the whole contents of the reservoir.
Old 02-03-10, 02:55 PM   #6
johnnyrod
johnnyrod's Avatar
Yep, possibly a bit of grit or something hard trapped in the cones so it's not shutting off (assuming it isn't scored)
Old 02-03-10, 07:38 PM   #7
5hort5
Excellent thanks, are the bleed nipples at the front and rear the same size? I have a few kicking around so I could stick in one of them if they are?
Old 02-03-10, 08:12 PM   #8
Spanner Man
Good evening all.
Somewhat correcting my earlier post ahem! If your bike is a Curvy all the bleed nipples will have a 7x1mm thread.
If you have a Pointy, the front calipers will have a 7x1mm thread. The rear will be an 8x1.25mm thread.
Cheers.
Spanner Man
Old 02-03-10, 08:27 PM   #9
5hort5
Thanks spanner man, sounds like a job for Thursday, bit of fishing tomorrow me thinks
Double banjo brake bolt with bleed nipple northwind For Sale - SV's and SV related items 6 13-02-10 06:53 PM
Brake Bleed nipple/Mityvac/Brake Fluid query Ceri JC SV Talk, Tuning & Tweaking 15 20-01-09 02:04 PM
brake caliper bleed nipple size stuballs SV Talk, Tuning & Tweaking 6 02-12-08 05:28 PM
Bleed Nipple Size? pmapp SV Talk, Tuning & Tweaking 12 30-04-07 11:31 AM
How do I get a snapped bleed nipple out of a caliper? Cloggsy Bikes - Talk & Issues 19 19-01-06 10:20 PM
