Old 27-03-10, 05:53 PM   #1
Amanda
Default Amanda's got the spanners again! Crash bungs and drain holes.
Yay!!!
Fixed the bike, in more ways than one....
1. Was not fired up and when it did it sounded like only one cylinder again and had FI error on dash. Cleaned out the drainage hole on the front cylinder and gave it a squirt of WD40 as per the previous thread advice. Fired her up and started first time, error code gone and running sweet again. Amazing!!!!
2. Took off the lower fairings. Removed the old crash bung on off-side and the brackets on both sides. Replaced the bolts and fitted the R&G Bungs. Had a bit of a mare getting the main engine bolt off. A 2 man job so I did get Chris to help. Fitted the new engine bolt, adjusted the R&G Bung bracket to get it all together. Tightened all the bolt and bingo new R&G Bungs fitted.
Have left the fairings off as I want to get some new bolts as 3 out of the 4 are different. Also the near-side bung will not come off the bracket so I'm gonna try and dremel it tomorrow!!
Anyway, I good day for the spanner wielding girlie!!!!
Old 27-03-10, 06:04 PM   #2
Default Re: Amanda's got the spanners again!!
Originally Posted by Amanda View Post
Yay!!!
Have you bought the fender extenda yet. If you haven't I'm gonna get cross
Old 27-03-10, 06:09 PM   #3
Amanda
Hahaha, Yes I have it here. The next and final jobbie to do!!!!
Old 27-03-10, 06:13 PM   #4
robh539
I hated having to fit mine. To fiddly to get the dam mudguard back on
worked a treat tho.
Old 27-03-10, 06:18 PM   #5
Holdup
OI!!!
That title is copyright of me!
Oh and dont break anything again
Old 27-03-10, 06:19 PM   #6
Amanda
worked a treat tho.
Why's that?? Cos its fiddly getting it through the forks??
HU - It's a compliment, you should be thankful for the attention
Old 27-03-10, 06:21 PM   #7
I don't know how youre going to fix it, but the sticky tape and screws suplied aren't my favourite.
You can glue it on with araldite or clear silcon sealant. I used araldite on mine, but its messy and impossible to get off once its set
If I were to do it again, I'd use clear silcon sealant. Just use it on the part where the sticky tape is on the fenda extenda
You'll need some clamps to hold it in place whilst the glue or silcon sets, if you were to use this method.
Oh, and its much easier to take the mudguard off and do this
Old 27-03-10, 06:24 PM   #8
Holdup
Ill let you off this time
Old 27-03-10, 06:27 PM   #9
robh539
Oh thats where i went wrong
As Mavizcap says def the screws to long anyway, and follow is advice and all will be well
Old 27-03-10, 06:39 PM   #10
Amanda
Default Re: Amanda's got the spanners again! Crash bungs and drain holes.
Right, so I just looked at the packet and there are only 4 screws with it and the tape on the fenda already.
Are you saying don't bother with the screws at all and just silicone it in place??
I can't see how you can use the screws anyway? The holes in the fenda are bigger than the scews.
Bag o' Spanners.. LK-SV SV Talk, Tuning & Tweaking 11 12-10-09 08:31 PM
Spanners not required....unfortunately rictus01 Bikes - Talk & Issues 24 17-08-09 09:33 PM
So I need some new ring spanners timwilky Idle Banter 23 09-02-09 11:51 AM
Get yer spanners out! jonboy Idle Banter 14 18-02-06 03:22 PM
Engine Protection/Crash Bars versus Crash Bungs SV's are gooood SV Talk, Tuning & Tweaking 6 24-11-05 06:07 PM
