Old 30-03-10, 01:23 PM   #1
Ceebl
Default Electrical part on carbs?
My curvy sk1 is currenty in bits gettin lots of things done to it and I'm just wondering, why do I hav an electrical connector wired into the side of my carb? Surely theyr all vacuum and cable driven and the choke is cable driven also? Is it likely to b a heating element to aid cold starts or does my k1 hav some sort of
mixture sensor? It's on the rear carb on the brake lever side of the bike, near the cylinder manifold part, small black object held on with a screw at each side, sleeve comes off it to connector lol which splits to yellow, black and blue wires if Im seein these correctly? Any ideas what this is?
Old 30-03-10, 01:24 PM   #2
Ceebl
Default Re: What is this???
Far as I can see from here there is not one on the front carb
Old 30-03-10, 01:28 PM   #3
fizzwheel
fizzwheel's Avatar
Without a picture of said connector or carburettor its hard to tell at a guess I say it was probably the wiring for the Carb heaters.
Old 30-03-10, 01:39 PM   #4
punyXpress
punyXpress's Avatar
Throttle Position Sensor lives there.
Now: Street Triple R
Old 30-03-10, 01:45 PM   #5
Throttle position sensor.
Old 30-03-10, 02:12 PM   #6
Ceebl
Why wud the carbed k1 model need a tps andy is it only on one?
Old 30-03-10, 03:41 PM   #7
Default Re: Electrical part on carbs?
Just one yes.
It gives more ignition advance under cruise settings to give a little better economy.
Old 30-03-10, 04:18 PM   #8
Ceebl
I did not know that!! That's rather cool! Thanks org (especially y_c with the neverending knowledge :P )
Old 31-03-10, 10:15 AM   #9
BigBaddad
each carb bowl has two wires connected,(one has a flat blade connector the other is next to it and has a pin type connector) these are the heaters to prevent icing. The other thing is the TPS as Yorkie_chris says.
Hope this helps.
Old 31-03-10, 02:21 PM   #10
embee
embee's Avatar
There is a setting procedure for the TPS on the carby model.
You'll find there's not much adjustment on the slots, but get it as near you can, it's not over critical.
carbs 99-02 daz_ash For Sale - SV's and SV related items 6 29-12-09 12:29 PM
What's this electrical part? twonky SV Talk, Tuning & Tweaking 15 10-02-09 01:09 AM
carbs help addicted to rage SV Talk, Tuning & Tweaking 10 16-11-07 02:02 PM
Set of carbs. Nekkid Stuff Wanted 0 15-04-07 12:24 PM
Anyone know what the green box electrical part is called? lockery SV Talk, Tuning & Tweaking 14 15-04-06 09:00 AM
