Old 31-03-10, 11:53 AM   #1
lloyd_christmas
Default Power to coils but no spark
1999 SV650 won't start.
Neither cylinder has a spark but 12.5V is going to both coils.
Electrics work, engine turns over etc.
The last two times I started the bike before the time wouldn't start, it was hard to start, but once going seemed absolutely fine.
I have changed the plugs, still no spark.
I have remove one of the spark plug caps to check for a spark directly from the HT, still no spark.
The is around 12.5V going to the coils with the ignition on, when i crank the engine this drops to around 9.5V, is this correct?
I have checked the pulse generator coil as per the manual, the resistance of it was within the acceptable range and there was no continuity between it and ground.
I have a multimeter and a manual, what should I try next?
Thanks
Old 31-03-10, 12:01 PM   #2
Default Re: Power to coils but no spark
9.5 a little low, try pop it on charge for a bit, eliminate that easy one first.
A question about coils hardhat_harry SV Talk, Tuning & Tweaking 7 10-11-09 09:07 PM
Ignition Coils - Anyone got a set? kbh Stuff Wanted 2 08-08-09 12:14 PM
Tesla coils... well I NEVER! Ping Idle Banter 13 13-07-07 02:24 PM
ignition coils stumpy1 SV Talk, Tuning & Tweaking 10 22-06-06 05:31 PM
Coils Iansv SV Talk, Tuning & Tweaking 6 28-01-05 09:41 AM
