Old 12-04-10, 12:40 PM   #1
toby_smith
Default Removing Grab Rail from 2001 SV650S
Hi there,
If i was the remove the grab rail from the above bike, would there simply be a couple fo small holes where it mounts, or is there something considerably less sightly than that under it?
Cheers,
Toby
Old 12-04-10, 12:58 PM   #2
Default Re: Removing Grab Rail from 2001 SV650S
There will be just two spaces where it was. You can buy shutters for them
I just put a rack on the back, I don't notice the gaps.
Old 12-04-10, 01:00 PM   #3
davepreston
when you remove the 2 bolts it lifts off without issue, then you are left with two gaps in the plastic which can let water into the rear seat compartment but this does not tend to be a issue,you can buy infill panels or just make some to make it look tidy, but all of this has no effect to the bike in any structural way
Old 12-04-10, 01:01 PM   #4
P-J
Hi there.
Should be a simple matter of removing pillion seat, remove the 2 bolts holding the grab rail and then replacing pillion seat or seat cowl. Nothing complex. There will be a gap just toward the 'rear' of the seat/cowl where the grab rail comes out but IIRC there are "gap-fillers" available. I'm sure someone on here will clarify!
PJ
Old 12-04-10, 01:02 PM   #5
P-J
Wow look at all thiose responses.....Mega quick!
Old 12-04-10, 01:04 PM   #6
toby_smith
hi guys,
does anyone know wher I can buy the little infill panels from which will hide the holes?
thanks,
toby
Old 12-04-10, 03:12 PM   #7
toby_smith
Just scoured the internet. Called every aftermarket parts supplier in the world (well, nearly) and no one sells them!
Ideas?
Old 12-04-10, 03:18 PM   #8
I don't like to recommend them as a company, but Banditmania did sell them. You could try them.
The correct name for them are saddle shutters.
HTH
Old 12-04-10, 03:42 PM   #9
toby_smith
Found them! cheers.
http://www.banditmaniashop.co.uk/sv6...ers-1122-p.asp
I was expecting two little bits of plastic. £40 though?
I assume the price is due to the colour coding is it?
Removing Pillion Grab Rail Anita SV Talk, Tuning & Tweaking 7 04-10-09 07:55 PM
k2 SV650s GRAB RAIL andy1505 For Sale - SV's and SV related items 2 08-05-08 10:09 AM
K2 SV650s Grab rail andy1505 Stuff Wanted 0 08-05-08 10:03 AM
2001 grab rail free(ish) to a good home! Jester666 For Sale - SV's and SV related items 1 29-04-07 11:29 AM
gaps left after removing grab rail ArtyLady SV Talk, Tuning & Tweaking 11 31-12-04 06:57 PM
