Old 16-04-10, 10:41 PM   #1
Preston
Default Brembo M/C
anyone know what size brembo M/C will fit a 2001 sv650s?
unlike pazzo they dont list the make of bike they fit, just the diff size ones.
any ideas?
Old 17-04-10, 01:54 AM   #2
zadar
Default Re: Brembo M/C
They will all fit but you want 19x18 or 19x20, those are what most people use.
Old 17-04-10, 05:38 AM   #3
Preston
any reason why?
what dos teh 18x19 or 19x20 mean lol not fitted brembos befor.. used em on other mates trake bikes thats why i wanna fit em to my road bike
Old 17-04-10, 08:05 AM   #4
zadar
first number (19) is master cylinder bore. Second number (18, 20) is leverage ratio, distance from levers pivot to where plunger is attached on lever. 18 is shorter than 20 (closer to levers pivot) so you will have to pull lever more in order to push plunger same distance you would with 20. 18 feels softer and you apply brake power by pulling more while 20 feels harder and you have to squeeze it harder to get braking power.
There are also new ones which are adjustable for leverage, they simply move plunger point along lever by turning nub.
If you buying none adjustable it is better to get 19x18 because if you don't like lever travel you just buy 20 lever and you get 19x20. It can work other way around also but it puts plunger on more angle.
brembo master cylinder stamasman SV Talk, Tuning & Tweaking 3 21-02-10 11:10 PM
Brembo service parts dirtydog Bikes - Talk & Issues 16 30-06-09 02:18 PM
Brembo Mastercyl Warning Robw#70 SV Talk, Tuning & Tweaking 13 08-12-07 07:32 PM
Brembo vs Marchesini wheel northwind Bikes - Talk & Issues 5 13-01-07 07:39 PM
Brembo master cylinder vs. OEM the oaf SV Talk, Tuning & Tweaking 12 30-04-06 06:35 PM
