Old 21-04-10, 10:00 PM   #1
SVMAT
Smile Clutch, EBC or Barnett?
Hi all i do beleive my clutch is on its way out as it slips even though it is adjusted poperly (worm drive) and cable. I am looking to replace it but dont know wether to go with ebc or barnett, has anyone had any experience of either clutches? i do pull quite alot of wheelies which is probably the reason its worn so am looking to get stiffer springs and uprated plates. The bike is a faired 650 on a 54 plate with 28000 miles. Any reviews ir recomendations would be much appreciated.
Matt
Old 22-04-10, 05:51 AM   #2
Spanner Man
Default Re: Clutch. EBC or Barnett
Good morning.
EBC are a low budget replacement clutch. There's nothing wrong with them but, they only supply friction plates & springs.
Whereas, Barnett also supply the plain steel plates. Which you will need to do the job properly.
I've fitted loads of both, & my preferred choice out of the two would be Barnett.
Cheers.
Spanner Man
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Do I need a new clutch? brenthilg SV Talk, Tuning & Tweaking 10 06-10-06 12:37 AM
Barnett springs for curvey clutch svrash For Sale - SV's and SV related items 3 16-03-06 12:34 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
