Old 22-04-10, 02:01 PM   #1
454697819
Default BIOS password Retrieval
Long story short I am locked out of a BIOS, I need to get back into the bios to change some settings,
I have done the battery out trick, and am currently re building the machine to see if this has worked, failing that there were no reset jumpers on the p200 motherboard.
Does anyone know a legit working bios password tool..
ps the supplier has gone bust so cant get the original from them
Alex
Old 22-04-10, 02:17 PM   #2
Geodude
Geodude's Avatar
Default Re: BIOS password Retrieval
I once did this by pulling out a stick of memory (with pc unplugged) then started pc and it noticed the change and let me into bios.
Old 22-04-10, 02:48 PM   #3
beabert
theres usually a little jumper switch on the mobo somewhere to clear the password. (oh lol re read)
Old 22-04-10, 05:50 PM   #4
Davadvice
whats the manufacturer/ exact Model No of the Mobo ? there should be a way to reset the BIOS even if it's not a traditional Jumper. it may be a switch or there may be a bridge you need to make.
Old 22-04-10, 06:25 PM   #5
phi-dan
phi-dan's Avatar
Dropping the battery should do the trick, but sometimes it helps to hit the power switch as well (with the mains and battery disconnected). This should drain all charge on the board and effectively reset the BIOS to factory.
On some of the older compaq boards there was no jumper either, but there was a button carefully hidden on the mobo that did the same thing.
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 22-04-10, 07:09 PM   #6
beabert
dip switches
Old 22-04-10, 07:16 PM   #7
fizzwheel
fizzwheel's Avatar
Jumper is normal, but sometimes dip switches will do it. Battery out doesnt always work. I used to find taking the bios chip off of the motherboard itself ( if possible ) would sometimes reset the bios back to factory defaults, but it is a piece of p*ss to damage the chip so be careful !
Old 23-04-10, 07:09 AM   #8
454697819
managed to clear the password using the battery trick... re flashed the bios but the damn thing still wont let me re install windows as it is telling me the hard drive isn't present, its usually down to a sata setting in the bios but there isnt one... oh ffs..
Old 23-04-10, 07:15 AM   #9
ThEGr33k
You sure the HDD is a good one? Plugged power in (all the basics)? If the power is in can you hear it spin up when powered up?
Are there no options in the bios to show what SATA drives are connected?
Old 23-04-10, 07:42 AM   #10
suzsv650
Therre will be a jumper on the m/b somewhere jump it over start up the PC reset your settings shut down PC jump the jumper then set a new password. Job jobbed.
Whoops should've read the rest of the Posts before....
*urgent* anyone else heard about the password leak? Owenski Idle Banter 23 06-10-09 12:42 PM
