Old 26-04-10, 08:16 PM   #1
larssonn
Default Rear suspension tool
Is it just me or is the tool you get with your SV to move the rear preload up and down pretty naff? The metal rounds too easy and I ended up using mole grips which isn't ideal. Does anyone have any tips to adjust the rear preload easily?
Old 26-04-10, 08:19 PM   #2
davepreston
Default Re: Rear suspension tool
hammer and punch
Old 26-04-10, 08:34 PM   #3
7755matt
Proper C spanner, probably about a fiver
Old 26-04-10, 08:42 PM   #4
larssonn
Ah cheers. I thought Suzuki were the only dudes that did this part. I did a search and they are pretty cheap. You get adjustable ones but not sure if i need that just now.
Old 26-04-10, 09:19 PM   #5
The standard tool is fine - unless the adjuster is a bit sticky.
Perfect suspension fork bush and seal fitting tool. beabert SV Talk, Tuning & Tweaking 6 31-05-13 03:01 PM
rear suspension set up walkaboutandy Thames Valley 0 13-03-09 04:27 PM
raised rear suspension antony SV Talk, Tuning & Tweaking 1 16-05-07 11:50 AM
rear suspension stev SV Talk, Tuning & Tweaking 10 11-06-06 11:11 PM
Rear suspension carlSV SV Talk, Tuning & Tweaking 4 27-05-06 06:47 PM
