Old 28-04-10, 11:38 AM   #1
FG1
Default Smoking oil cooler.
Ooops, got home about 10 min ago and parking the bike up noticed smoke coming from the oil cooler area.
On closer inspection one of the hoses, the one on the right as you sit on the bike, seems to be covered in oil. I am going to take the belly pan off and have a closer look when it has cooled down but just wondered if this had been raised before.
Fingers crossed it's a quick fix as I am supposed to be going camping this weekend.
Old 28-04-10, 11:40 AM   #2
Stig
Default Re: Smoking oil cooler...
Not much to go on there. Probably a lose oil pipe connector?
Old 28-04-10, 12:10 PM   #3
lee67
had this happen on a few bikes, the hose seals will have perished more than likely, cheap fix..or if bling is preffered a nice new hel oil cooler looks ace
Old 28-04-10, 01:19 PM   #4
Unlikely on a bike the age of yours, but carefully check the oil cooler itself. Where the hexagonal sections meet the body of the cooler I've seen a couple with hairline fractures.
If you find it's the unions that are leaking, don't just nip them up as the threads are relatively weak, loosen first so as to get an idea of the torque they were previously at. The unions use soft aluminium banjo washers so there is a durable seal at low tightening torques, don't use anything else.
When undoing or refitting the banjos, firmly counter-hold the hexagonal section on the cooler witha suitable spanner - the torque must not be applied to the body of the cooler - it's easily damaged.
Old 28-04-10, 01:53 PM   #5
Spanner Man
Good afternoon all.
I've seen some SV's where the oil pipe has rusted through under a short section of PVC sleeving which is around the metal section of the oil pipe.
New pipe time I'm afraid!
Cheers.
Spanner Man
