Old 03-05-10, 03:22 PM   #1
-Ralph-
Default Rear sprocket bolts
Just taken the rear sprocket carrier off my XT600 to fit a new sprocket.
The old sprocket was not held on with bolts, its nuts on a double-end threaded rod as shown in the middle of the new sprocket in the photo. The threads are knackered with loctite and a couple of the nuts stripped the threads they were on, so I have decided to replace them all.
Can I just use an ordinary bolt from B&Q or would these need to be a hi-tensile item?
I've found bolt and tab kits for all kinds of off road bikes on Google, but not for an XT600.
Thanks
Old 03-05-10, 03:26 PM   #2
thefallenangel
Default Re: Rear sprocket bolts
take bolt to B+Q and match up. If they are the same as SV they should be 8mm threads although they look like they could be 10mm
Old 03-05-10, 03:48 PM   #3
-Ralph-
Thanks! The manual mentions nothing about using blue loctite on them. Do I need to use loctite, or will the specified torque (61nm) be sufficient?
Old 03-05-10, 04:22 PM   #4
thefallenangel
I didn't use loctite on mine and they are still tight after 5 thousand miles but if there's some there you should get some as you'll find other bolts will need it.
Old 03-05-10, 07:21 PM   #5
-Ralph-
Sorry, another question. Do I need to have the un-threaded shoulder on the bolt like this one?
Been up to B&Q and they had shouldered bolts, but all of them were too much shoulder and not enough thread.
Would the bolt not be weaker where it goes through the sprocket if it was threaded at that point. Google searches have bought up a few folk that have suffered sheared sprocket bolts whilst on the move.
Old 03-05-10, 08:24 PM   #6
What size bolts you after col, i have shed loads of stuff like that, all gained from my previous employer
Id be wary about using cheapo bolts on something like that, b&q are gonna be mild steel at best.
Use loctite anway, what you got to lose, i have some threadlocker if you wanna use some.
Old 03-05-10, 08:25 PM   #7
That would have been the tensile strength of the bolt i think not the thread .
Old 03-05-10, 08:37 PM   #8
Shouldered are stronger in shear at a point because there's more metal there... of course if it then transmits the shear to a threaded bit it will make no odds.
Studs will take more tension than same sized bolt going into ally especially. You checked with yam or are they hilariously expensive?
PM carnivore, he has a brace of SRX600s so knows the beast.
Old 03-05-10, 09:41 PM   #9
Don't use B&Q bolts, and definately don't use a bolt with the thread all the way along - the plain section is in an aluminium hole and the running torque presses this against the side of the hole, threads will gall the side of the hole and oval them.
Old 03-05-10, 09:56 PM   #10
-Ralph-
OK, thanks everyone.
Which chain/sprocket and replacement bolts Guy SV Talk, Tuning & Tweaking 13 11-08-09 07:55 AM
Bolts for rear footbeg hangers??! adamw2k2 Stuff Wanted 4 16-03-09 09:15 PM
k3-k6 cush drive and sprocket bolts drwracing Stuff Wanted 1 02-08-07 09:31 AM
Sprocket cover bolts (pointy) thor SV Talk, Tuning & Tweaking 6 19-11-06 05:29 PM
Rear Sprocket Nuts And Bolts sv182 SV Talk, Tuning & Tweaking 5 21-12-04 11:16 PM
