Mini-Twins Goto Minitwins Official Site
Old 04-05-10, 08:58 PM   #1
mike_red2uk
Default just started minitwin with NEMCRC and Derby Phoenix
Finally made the step from trackdays to racing with my 2000 curvy,
Done croft and cadwell just so far !
had misfiring problems both times, poorly bike off the get dyno'd and tuned properly, was running 1st at Cadwell, 4 laps in misfiring started and finished 14th GUTTED !!!!!
looking forward to 2010 fianances permitting !!!
cheers
mike #54
(and my bike trigger)
Old 06-05-10, 02:01 PM   #2
Berlin
Default Re: just started minitwin with NEMCRC and Derby Phoenix
You going to be at East Fortune on the 15th 16th mike?
C
Old 06-05-10, 07:07 PM   #3
mike_red2uk
only of i can book me bike into a dyno, i divibt want to waste a nother regs cost
the tuner recommended by me mate peter minns, a lad at malton is fully booked till the TT,
ganna try ringing the lad at PC performance at ashington,
what you riding pal ?
Old 06-05-10, 07:45 PM   #4
Tim in Belgium
Is it a loose coil connection causing your misfiring issues?
Old 06-05-10, 08:25 PM   #5
mike_red2uk
no tried all that !!!!
cheers
Old 07-05-10, 07:37 AM   #6
Berlin
I'm on A 600 Mike. Number 33
Even though a guy I asked said he wouldn't take his wheelbarrow to him, there's also the guy at Northallerton.
Have you changed the plugs? Checked the coils and leads for spark leakage? A high speed misfire could also be fuel starvation. Check there are no kinks in the fuel lines. If there are any filters in your fuel lines try running it without them to see if they are causing too much restriction.
Doesn't sound like the carbs but I'd clean them out (including all the jets) and check they go back on without any air leaks in the rubbers.
Good luck sorting it!
C
Old 07-05-10, 09:56 AM   #7
mike_red2uk
who the dyno lad at ashington ????
We'll im having a good strip down this weekend (the bike not me !)
then trusting wiv the dyno run and my normal cheeky midday run upto towlaw all is good with the SV then im east fortune bound,
im sure not to break any records tho as ive never ridden it b4 and there isnt a test day,
even if the bike dont run i'll prop pop up to see people and watch, so if i find you i'll say hi pal .
I'll post how the bike gans
mike
Old 08-05-10, 01:23 PM   #8
mike_red2uk
right just had bike on dyno. much to my surprise it was running lean, weve took the factory pro 140 jets out and put in the 145, gave a lovely smooth curve upto 68bhp at the wheel. flattened off at high revs so biggers jets would get more BHP.
Im ordering 147.25 and 150, mebbies even 152.25 jets from America,
So the bike good to go for eastfortune this next weekend, then i'll fit the biggers jets and dyno it again later in the year.
by the way when it was missfiring it was making 55bhp !!!!!! and i was wining on that at Cadwell !!!!!!!!
Old 08-05-10, 05:23 PM   #9
Berlin
You're ordering jets from the US?
Can't you get them here?
Glad you got it sorted
Old 08-05-10, 05:45 PM   #10
mike_red2uk
was going for the factory pro ones, but as yorkie said im gettin same here
Nemcrc SteveJ Mini-Twins 43 13-05-10 08:35 PM
Phoenix SV gzminiz Photos 19 27-04-09 11:01 AM
Project Phoenix Blue_SV650S Bikes - Talk & Issues 93 03-04-08 08:35 AM
Cadwell Park, Derby Phoenix, This Weekend: MrMessy Rideouts & Meetings 0 22-09-06 09:31 AM
Cadwell Park, Derby Phoenix, This Weekend: crf450r Idle Banter 0 08-01-70 02:32 PM
