Old 10-05-10, 05:41 PM   #1
600+
Default Any electricians on here?
Existing oven is falling apart so have seen a recon AEG on ebay for £100 with 6 months warranty and PAT tested. Spoke to the guy he says goes to a 13amp socket.
Anything I need to check on mine?
Thanks
Old 10-05-10, 05:45 PM   #2
Default Re: Any electricians on here?
Should be perfectly ok on a standard 16 amp ring, or could be 32 amp ring in your kitchen.
Some people even have a socket installed directly off the cooker switch which is 40 amps.
Old 10-05-10, 05:51 PM   #3
Airwolf
alot of new ovens are 13amp plug into a normal plug socket, no problem,
if you have a 40 amp wiring in point, if you know someone/ or you are ok with electrics wire up a 13amp fused spur to down grade the line for safety.
Old 10-05-10, 05:58 PM   #4
No need, the plug on the oven will be fused.
Old 10-05-10, 06:04 PM   #5
Kilted Ginger
You wont be able to replace the existing 40amp outlet with a fused spur as the cable physically wont fit.
You could remove the plug and wire directly into the cooker outlet but you would need to resize the circuit breaker in the fuse box. Or a fault in the cooker would melt the cooker wiring before lifting the 40amp breaker.
Easiest option is just to plug it into a normal socket if you have one handy.
Otherwise you need to get a bit 6mm cable wire from the cooker outlet to a fused spur then either wire the cooker directly into this or install a socket fed from the spur......
Old 10-05-10, 06:18 PM   #6
Find a socket and plug it in
Don't cut the plug off to connect it to a spur/cooker unit or you'll loose the warranty. If you don't have a socket there already, phone an electrician
Old 10-05-10, 06:19 PM   #7
Stuuk1
Yep, what they all said. Im a sparky and i can say no more...
Old 10-05-10, 06:23 PM   #8
Good to know my info was coche
I fit kitchens but have a sparks do the stuff im not allowed to do, even though i can.
Old 11-05-10, 06:14 AM   #9
600+
ah many thanks folks! I guess all will be revealed when I remove the old oven
Old 11-05-10, 09:01 AM   #10
thefallenangel
don't you have a cooker switch with a 13 amp socket on it too?
If not just buy one and fit it. Obviously if you have part P blah blah blah crap which means a kitchen fitter can wire a kitchen in but and industrial based electrician can't.
Otherwise as has been said break the ring circuit and add a socket in for the cooker.
Paging the auto-electricians Lozzo SV Talk, Tuning & Tweaking 15 19-02-08 02:43 PM
Any electricians furrybean Idle Banter 9 12-11-06 03:47 PM
calling all electricians, or anything close. Warren Idle Banter 18 18-09-06 08:14 PM
