Old 03-06-10, 08:56 PM   #1
antony
Default Removed STV - now won't run.
ok bored out my spare throttle bodies and fitted bigger butterflys totally scrapped all the computer controlled secondary stuff my guessing was that it should run but with fault codes am i right in thinking this as it wont start now
Old 03-06-10, 09:07 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: bored out throttle bodies
duh, it needs to be plugged in or else the system will complain, plug in the actuatior and see if it all works again
if you want to remove this stuff there are ways usualy involving resistors etc, but not sure for such a major component as an actuator which i suspect has some feedback loop
Old 03-06-10, 09:35 PM   #3
antony
yes i did plug a second pair of throttle bodies into the system that was removed but still no joy i have also tried a set of throttle bodies manually opened the actuator and unplugged the top end components and the bike did run with the fi light on think i will just keep trying components maybe it will worl maybe it wont
Old 03-06-10, 09:36 PM   #4
TSM
The Sick Man
TSM's Avatar
bridge the service mode plug and check the codes and list them
Old 03-06-10, 09:43 PM   #5
antony
yes its c14 tps sensor and c28 secondary actuator the thig that i am trying to get across is that before any mods i unpluged the actuator and secondary tps sensor and the bike still ran but since the mods it doesnt
Old 03-06-10, 09:52 PM   #6
TSM
The Sick Man
TSM's Avatar
put it all back and see if it works again, im not sure how the TBs work fully on the pointies as ive never seen them but checkover everything again and see if you missed somthing
Old 03-06-10, 10:00 PM   #7
antony
yeah going to put the standard ones back on see what happens then just keep messing till i sort it
Old 04-06-10, 09:38 AM   #8
Default Re: Removed STV - now won't run.
have you tried turning it off then on again..
something fizz taught me ..
Old 07-06-10, 08:46 PM   #9
antony
sorted now ended up being a faulty tps sensor so bored out to 42mm time for some dyno to see if it produces a few more horses
Old 25-06-10, 10:30 PM   #10
antony
just to let you guys know it added around 4 bhp and upped the torque curve as well so pushing just above 80bhp so it not a bad little mod really
Baffle Removed hindle8907 SV Talk, Tuning & Tweaking 20 17-06-09 09:38 PM
Just had a listing removed from ebay... Paul the 6th Idle Banter 25 21-11-08 11:40 PM
Has anyone ever removed the whole petrol cap? DarrenSV650S SV Talk, Tuning & Tweaking 14 02-10-07 04:54 AM
Removed Stu For Sale - SV's and SV related items 5 18-08-06 09:05 AM
removed tigersaw For Sale - SV's and SV related items 0 16-05-06 01:47 PM
