Old 14-06-10, 08:19 PM   #1
Elltg
Default Which headlight wires curvy sv650s
I have a faired 01 curvy sv650 and i am replacing the lights amongst other things. I have noticed the stock lights were driven by 2 sets of 3 colour coded wires on the detachable wire loom.
i have interpreted them as follows from here
Yellow
White
Black w/White tracer
My question is why is one set equipped with thicker wires than the other? Does one supply more power? If so I would be interested as i could do with the extra power. It is currently hooked up to the thinner ones because i wired it before i noticed and my light is a bit dull.
I wondered if anyone just knew outright as I have tried to use the multimeter to test the current but I cant seem to get a reading as I don't know how to measure amps with a multimeter.
Old 14-06-10, 08:43 PM   #2
Default Re: Which headlight wires curvy sv650s
yellow and white, one is dip one is main.... black/wh is earth.
I would guess with the lamps being 60/55s the thicker wires would be for main beam. Worth checking you don't have bad contact anywhere.
I would not try measure amps with multimeter for big stuff (headlight works out to be 5 amps approx), it is hard to get a good contact and thus reliable reading.
Old 14-06-10, 09:13 PM   #3
phi-dan
phi-dan's Avatar
Yellow = Main
White = Dip
Black/White = Earth
Both go through 15A fuse so should be capable of drawing same power/current down each line.
hth
Was: Red curvy S: crash bungs, double bubble screen, fenda extenda, HEL front lines, OEM belly pan
Now: Blue FZ6 Fazer
phi-dan is offline   Reply With Quote
Old 14-06-10, 09:36 PM   #4
Elltg
I figured the main and dip had that working with the normal switches, the point i was making is that there is one thin white, thin yellow AND thin black/white and one thick white, thick yellow and thick black/white. That confused me... any ideas?
Old 14-06-10, 11:14 PM   #5
Miss_Undaztood
The thick wires probably supply the power for both lights from the fusebox and the thinner gauge supply the second light from the first ?
So the thick wires supply the power for 2 headlights, the thinner wires just for 1.
Old 14-06-10, 11:20 PM   #6
Elltg
Pretty likely actually thinking about it, the rest of the wires just split of like that. Ta! I've been doing it all day i always start overlooking the simple answers.....
sv650s headlight daz_ash Stuff Wanted 0 15-12-09 04:31 PM
SV650S curvy headlight mod picasso194 SV Talk, Tuning & Tweaking 19 18-01-08 07:27 PM
Headlight for a SV650S K3 stangeor Stuff Wanted 0 10-02-06 10:20 PM
SV650S import headlight svrider-ni SV Talk, Tuning & Tweaking 6 14-11-05 09:59 AM
What Headlight bulb for the 01 SV650S? triehl27 SV Talk, Tuning & Tweaking 2 22-09-04 09:25 PM
