Old 03-07-10, 10:06 AM   #1
sv650s 04
Default Feeling every bump in the road?
Since I brought my 650s a month ago I am feeling every bump in the road, big or small, is there a way to solve this? wondering if the pre-load is set wrong Has anyone else had this problem? I am only a light fellow, maybe this has something to do with it?
Any thoughts welcome
Old 03-07-10, 10:10 AM   #2
Dave20046
Dave20046's Avatar
Default Re: Feeling every bump in the road?
If the preload is screwed right the way in you'll feel them more. Is the suspension standard? If so it's likely just the state of the SVs standard suspension.
Old 03-07-10, 10:12 AM   #3
sv650s 04
Yeah it is a standard rear spring. Any way to make it more comfortable rather than buying a new one?
Old 03-07-10, 10:30 AM   #4
Dave20046
Dave20046's Avatar
Is it the rear that's the problem?
Old 03-07-10, 10:33 AM   #5
the_lone_wolf
Captain Awesome
the_lone_wolf's Avatar
It's an SV, the suspension was never that great to begin with tbh, mine managed the job but it's nothing next to something like the WP stuff on the KTM
(•_•)
( •_•)>⌐■-■
(⌐■_■)
Deal with it...
Old 03-07-10, 10:39 AM   #6
Dave20046
Dave20046's Avatar
I rode a standard sv back to back with mine the other day I thought I was riding faster than ever...looked down at the clocks and was doing like 50mph the things are so unstable!
Old 03-07-10, 10:50 AM   #7
fizzwheel
fizzwheel's Avatar
if you are light, then you should be more towards the weight range that the SV sprung for as standard.
If somebody has twiddled with your suspension settings you might find thats the cause of the problem.
First off, reset the suspension to its standard settings ( I dont know what they are but somebody on here will be able to tel you ) and also check your pressures are correct in the tyres ( 33psi front, 36psi rear ) Then go and ride it again.
If your bike has done alot of miles, it may be time for a front fork oil refresh and you may also want to think about fitting a replacement rear shock as they do tend to loose their damping when then have a lot of miles put on them.
But start with the basics first and then if you dont know what you are doing, ask in your local regional section and see if anybody can recommend somebody you can take the bike to who can set it up for you.
Old 04-07-10, 11:24 AM   #8
The opposite can be true too. If you're bottoming out everywhere it will feel rather harsh.
Too much preload or too little will both cause issues.
Old 04-07-10, 01:13 PM   #9
embee
embee's Avatar
If it's the front, it's possible the fork oil level is too high.
bump?? what's it mean charlie13 Idle Banter 5 26-10-07 09:22 AM
Feeling the call of the road again - NOT BIKE RELATED Ed Idle Banter 12 11-04-07 04:24 PM
Bump the Mrs! zx6man Pennine Massive 5 05-01-06 09:47 AM
What does *bump* mean? Smiler33 Idle Banter 1 07-01-70 12:59 PM
