Old 07-07-10, 11:01 AM   #1
JAWs
JAWs's Avatar
Default Powder coating wheels.
I'm thinking about having my wheels powder coated, will I need to remove the bearings or can I just mask them up?
JAWs is offline   Reply With Quote
Old 07-07-10, 11:08 AM   #2
Viney
Default Re: Powder coating wheels
remove the bearings. Also have you found anywhere? Mine need re-doing
Old 07-07-10, 11:22 AM   #3
Nobbylad
Nobbylad's Avatar
One of the .orger's brothers has just started his own firm doing this hasn't he?
Old 07-07-10, 01:11 PM   #4
_Stretchie_
Large Member
_Stretchie_'s Avatar
Yep, over in Chippenham
http://forums.sv650.org/showthread.php?t=148761
How to amuze an idiot:
Look right-> <-Look Left
Old 07-07-10, 01:19 PM   #5
cuffy
Coooeeee!
Check out my signature, links you to my brothers site.
Have a look >>HERE<<
Old 07-07-10, 01:23 PM   #6
Triple S, are the dogs, the most welll known company. Ex had one or two frames and wheels done by them.
Old 07-07-10, 03:31 PM   #7
JAWs
JAWs's Avatar
Does that mean I will need to replace the bearings and dust seals? Also, I assume that you need special tools to remove and replacethe bearings, is this the case?
Old 07-07-10, 04:04 PM   #8
Viney
Yes. Wemoto is your firend for bearings. Removing them, Hammer and a 3/8 socket extension is what i used for mine that and a Medium grade hammer.
To put them in, a few large washers and a length of studding with a couple of nuts. This draws them nice n even.
Dont forget your sprocket carrier as well and that also has a bearing.
Old 07-07-10, 05:14 PM   #9
danf1234
Triple S in bingley are the best and deal purely in bikes. They have done every part of my RGV 250 restoration. When I get the engine out they will be doing the frame as well. The work they do gives you the parts back better than new.
Old 07-07-10, 05:23 PM   #10
danf1234
Use the old bearings to knock the new ones back in.
powder coating FG1 Idle Banter 17 13-01-09 09:43 PM
powder coating wheels ging6996 SV Talk, Tuning & Tweaking 33 27-06-08 05:35 PM
all this talk of powder coating wheels... Draper Idle Banter 5 20-05-08 07:37 PM
powder coating weazelz SV Talk, Tuning & Tweaking 6 02-10-06 10:57 PM
Pics/Opinions of powder coating wheels andyb Bikes - Talk & Issues 18 11-04-06 05:40 PM
