Old 22-07-10, 08:18 PM   #1
Typhoon
Default Gear Linkage
Hi all, I need a gear linkage for m project however it differs from the stock SV linkage due to the new rearsets.
It now has a male end on the foot end and obviously still retains the female end on the selector shaft end. IIRC the SV requires a MALE/MALE rod (FNARRRR)
Any idea where I can get a Female LH Thread and Male RH Thread Rod made up?
Also any idea on a rough length and thread pitch size as I have nothing to go on.
Cheers.
Old 22-07-10, 08:21 PM   #2
husky03
Default Re: Gear Linkage
buy a tap and die set?
Old 22-07-10, 08:23 PM   #3
Typhoon
Got one but don't really fancy that. Plus the rod supplied is Female Female so I'd loose an inch on the rod as it would be hollow. So probably end up being too short.
Old 22-07-10, 08:23 PM   #4
who make the rearset? as they should sell the appropiate rod or linkage point
tap and die is a good option but difficult if you aint ever done it.
I need to be shown how to use 1 before i'm let loose
Old 22-07-10, 08:42 PM   #5
Nobbylad
Nobbylad's Avatar
Look on mcgill motorsports on ebay, I seem to recall they do specific stuff like that (or it may just be rose joints etc)
Curvy gear linkage rod Old Git SV Talk, Tuning & Tweaking 5 01-03-10 09:49 PM
Gear linkage end svrash Stuff Wanted 2 23-08-07 09:07 AM
Gear linkage. Jester666 SV Talk, Tuning & Tweaking 5 05-07-07 03:17 PM
Gear linkage - will one from an SV1000 fit? Rock Hopper Penguin SV Talk, Tuning & Tweaking 6 03-06-07 06:41 PM
Gear Linkage Adjustment - Should it be necessary ? leegriffiths128 SV Talk, Tuning & Tweaking 1 05-04-05 08:55 PM
