Old 02-08-10, 08:04 PM   #1
nik_nunez
Default looking to buy a new PC
looking for a new desktop unit, ive had my current one for about 5 years + and its really slow playing new games etc
dont really want to spend a huge amount, but want something decent for online games etc.
cheapest one i am looking at with a decent spec is either:
http://www1.euro.dell.com/uk/en/home...kdhs1&ref=dthp
the £499 one, ive looked at a few custom pc websites and they seem to be really expensive and not as good spec as the dell.
min spec i am after is roughly:
itel dual core 2.6ghz,
4gb ram (DDR3)
512 or 1gb graphics card (ati or nvida)
500gb hard drive
any feedback greatly appreciated
Old 02-08-10, 08:06 PM   #2
sauluk
Default Re: looking to buy a new PC
Build yourself?
I've got a really good spec PC and it was about £300 all in (apart from graphics which were another £150 a bit later)
Old 02-08-10, 08:08 PM   #3
barwel1992
how much do you know about PC's ?
Old 02-08-10, 10:02 PM   #4
coolevilangel
Aldi do pc's every now and again
Its where i got mine over a yr ago, and for the coin the spec was top notch!
http://www.aldi.co.uk/uk/html/offers...uys2_14867.htm
Old 02-08-10, 10:04 PM   #5
beabert
Its all about the gpu, get the system which has the best one within your budget.
Old 02-08-10, 10:09 PM   #6
nik_nunez
Don't know enough to build it all from
scratch, I have added bits, ram
chnaged fans etc but nothing major. The aldi one looks good buy the dell
one seems a better spec for a bit more
Old 03-08-10, 12:59 AM   #7
L3nny
L3nny's Avatar
If you know what part it what inside the case then you can build a PC, its so simple these days.
I am a bit out of touch on PC hardware these days but you could buy the items below for £380 and use it to upgrade your existing PC. You might need a new power supply as well and if you are running out of space another hard drive.
As has been said before the memory on the graphics card is a lot less important than the GPU speed, usual rule of thumb with graphics cards is more expensive = faster. Get the best you can afford.
Only thing to watch out on when ordering parts is make sure the processor fits the motherboard, make sure the socket type patches.
http://www.ebuyer.com/product/155434
http://www.ebuyer.com/product/179081
http://www.ebuyer.com/product/178943
http://www.ebuyer.com/product/227182
2015 GS 1200 Adventure
Old 03-08-10, 05:39 AM   #8
james160987
i may have a bundle for sale soon, not sure yet,
a cpu, q6600, 4gb ocz ram, msi board,
means ud need case,psu, hdd,dvd,gpu,
not sure what those bits above are worth currently
Old 03-08-10, 06:19 AM   #9
nik_nunez
ive had a good look inside my comptuer and can figure most things out, biggest problem is how do you know where all the little wires and connectors plug into the motherboard, i know the cd is labeled cd but most have no label at all, or can i just try and copy the current set up?
to upgrade my pc i would only need a new motherboard, ram, graphics card, the rest i could just keep as the cd and dvd writers are fine, have enough hard drive space, and the case is fine -
how would i know if my current power supply is enough for the new system? it current says on it, mercury ATX switching power supply, 400W, model kob ap4400xa -
(not sure where the soundcard is on my pc, unless its built into the motherboard)
Old 03-08-10, 07:29 AM   #10
L3nny
L3nny's Avatar
I think pretty much all the connections on a modern motherboard are unique. i.e. if it fits than that's where it's supposed to go.
Soundcard will probably be built in, look where your speakers are connected, that's the soundcard lol. Not much point getting a seperate soundcard these days as the built in ones are usually quite good.
400w may be a bit low if you want a kickass graphics card but see how it goes. If you keep getting crashes you might need to upgrade it.
