My golf started whining on the way home tonight
![]() The noise increases/decreases with speed, not revs. So I'm thinking it will be a diff gone ![]() How much will that cost to fix..... £1m? £2m? Or should I just turn the music up a bit more and ignore it until it snaps? grrrr I hate cars ![]() |
Could also be, 1 of your brake discs has a stone or something wedged or more likely a wheel bearing has gone, which is a hell of lot cheaper than a drive shaft.
Check your brake discs to see if they are very worn and the pads, if they are worn right down they will make a horrendous noise, albeit normally only when braking. |
Does the noise fade out or go when you dip the clutch? Which model golf is it?
Its the wing mirror
#5 | ||
Might be a bee stuck in there I suppose |
He's right, and its most probably female too. To check this, refer to your user manual.
#9 | |
#10 |
Trouble at 8,000 RPM | leesh00 | SV Talk, Tuning & Tweaking | 15 | 20-07-09 05:09 PM |
org trouble | kwak zzr | Idle Banter | 5 | 22-06-09 07:45 PM |
HID trouble. | yorkie_chris | SV Talk, Tuning & Tweaking | 33 | 30-12-08 12:22 PM |
car trouble | rowdy | Idle Banter | 18 | 16-08-08 04:37 PM |
In Trouble | timwilky | Idle Banter | 28 | 29-05-07 01:52 PM |
