Old 22-08-10, 05:34 PM   #1
Bedhead
Default C28 Fault code again!
Got the dreaded c28 code, bike is revving it's head off on a closed throttle, I take it it's unlikely to be a loose connection?
Old 22-08-10, 06:05 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: C28 Fault code again!
secondary throttle valve actuator
Old 22-08-10, 06:07 PM   #3
Correct. C28 = STVA
Old 22-08-10, 06:37 PM   #4
Bedhead
Megabucks then!
poo!
Old 22-08-10, 06:43 PM   #5
Check connections on the actuator first and then continuity on the relevant wiring between STVA and ECU - it may not be the actuator itself.
Old 22-08-10, 06:59 PM   #6
Bedhead
Checked the connections, all OK, if it's a wiring job, then that's something I'll not be too keen on getting involved in.
It only happens after a sustained period of full power, that's the annoying thing, ride easy and it's fine, give it the beans and it gives up the ghost.
Old 23-08-10, 11:53 AM   #7
GrahamB
Or get a simulator/eliminator from Decosse then lock it fully open.
Old 23-08-10, 12:00 PM   #8
TSM
The Sick Man
TSM's Avatar
not the best idea in our cold weather here as your auto fast idle will then no longer work correctly, that mod is for race bikes which are usualy on large thottle openings anyway
Old 28-08-10, 02:31 PM   #9
glang
Hi, if you havent sorted this problem I had exactly the same some time ago so have a look at the thread I started: 'fi fault light'.
Cheers glang.
Old 25-06-12, 08:29 AM   #10
Jynx
For those following this thread (like me) the thread mentioned above is - http://forums.sv650.org/showthread.php?t=99650
Anyone know what -C28 fault code is/means? sv650k4 SV Talk, Tuning & Tweaking 10 02-09-08 01:29 PM
one off FI fault DavieSV SV Talk, Tuning & Tweaking 24 21-02-08 11:08 PM
FI fault glang SV Talk, Tuning & Tweaking 0 19-12-07 04:49 PM
fault code antony SV Talk, Tuning & Tweaking 2 06-09-07 08:35 PM
My fault? Carsick Bikes - Talk & Issues 15 14-12-04 02:30 PM
