Old 31-08-10, 08:47 AM   #1
bengrrr
Default Engine mounting bolts help, what am I missing?
Hello All.
Forgive me if I get any terminology incorrect.
When i bought my SV the previous owner had some Bungs on the frame which had a bolt go through the lower middle engine mount.
I bought my lower farings and have put them on, thus taking out the bungs. So bolt and bungs removed at the time and I didn't have the original bolt to go back in its place.
So to my point. I bought a set of bolts on fleabay. but cant work out what i'm doing wrong as I don't have a bolt that goes through fully and cant work out what i'm supposed to have either side of the frame. Please look at the pic hopefully it'll explain. Am I missing something?
So I have new bungs fitted to the faring brackets that come with the lowers kit. And now no middle mounting bolt. Or now a middle mounting bolt that i can work out why i can attach it. Any Ideas would be great. Ta.
Here's the bolts I got...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWNX:IT
Here's the pics of where I mean....
And other side...
Old 31-08-10, 11:07 AM   #2
bengrrr
Default Re: Engine mounting bolts help, what am I missing?
Right looked on alpha Sports and think I've worked it out, if poss could someone be so kind as to upload a pic or their SV either side of their frame.
Pretty sure on the pic of my left side the bolt is to go in first and connect with a nut on the right side. Then the thing with the lock nut which you can see in my pic goes in after the bolt. Hence why it currently doesn't fit?
Old 01-09-10, 04:09 AM   #3
zadar
Actually bolt is last thing that goes in. All you need is bolt and nut, put it in and torque down.
Old 01-09-10, 08:21 AM   #4
bengrrr
Thats the problem though the bolt isn't long enough ?
Old 01-09-10, 08:37 AM   #5
zadar
You have wrong bolt. The longer one on that ebay link is not bolt you need. That one is for lower rear engine mount (#31).
Old 01-09-10, 01:19 PM   #6
bengrrr
Right bolts 31 and 32. But then the problem is what do they screw to? ill have anther play tonight im obviously missing something simple.
Old 01-09-10, 02:09 PM   #7
davepreston
no they are both the wrong bolts
you need 33 which is longer
32 is up and left just outside veiw of pic 1
31 is the one just up and right from the bolt your missing
Old 01-09-10, 03:59 PM   #8
bengrrr
Right so thats what i thought originally but its not long enough. Dave am i right in thinking i attach the bolt through the frame with nut first then the other parts i circled in alpha sports pic 2?
Old 01-09-10, 06:53 PM   #9
zadar
You don't have it, you have 31 & 32. There is no 33 on picture in that ebay link. 33 is also thicker than other 2 bolts.
Old 02-09-10, 08:22 AM   #10
bengrrr
Oh FFS knew it was something really silly that i didn't see. Cheers.
Missing 2 Screen bolts hongman Bikes - Talk & Issues 3 22-07-10 09:54 PM
Wanted engine mounting bolts for pointy weecorey Stuff Wanted 0 17-03-10 03:38 PM
Rear caliper mounting bolts GeoffB SV Talk, Tuning & Tweaking 18 24-06-09 09:44 PM
Help - Front Caliper Mounting Bolts SV Meldrew SV Talk, Tuning & Tweaking 19 11-02-09 08:13 AM
Where can I buy caliper mounting bolts? Binky SV Talk, Tuning & Tweaking 4 07-08-08 10:46 AM
