Old 30-09-10, 01:52 PM   #1
Paul the 6th
Paul the 6th's Avatar
Default Can anyone recommend any industrial strength decongestants please?
I would like my hearing back, I'd also like to be able to blow my nose without migrane powered pressure getting trapped in my sinusses and then slowly making horrible squeaky noises on the way out over the next hour... Off the shelf stuff doesn't seem to do much apart from make me feel like my lungs have been wrapped in cling film, so if anyone can help me out, I will be most grateful
Old 30-09-10, 02:10 PM   #2
beabert
Default Re: Can anyone recommend any industrial strength decongestants please?
Doctor will just give you pseudoephedrine tabs, never used it mind, most likely an ingrediant in some of shelf brands though.
Old 30-09-10, 02:15 PM   #3
kaivalagi
When I was regularly diving before now if I got bunged up I just double dosed sudafed...30 mins later hey presto, no nasty ear/nose blockages...it lasted a good couple of hours worst case
Old 30-09-10, 02:19 PM   #4
Paul the 6th
ah ha, sudafed abuse - why didn't I think about that! Cheers kaivalagi, will report back..
And thanks beabert, cba with doctors but am getting close to just going if it doesn't shift
Old 30-09-10, 02:22 PM   #5
Olbas oil is pretty good
That and whiskey
Old 30-09-10, 02:27 PM   #6
454697819
what the BSC hons spanner chappie said...
Old 30-09-10, 03:50 PM   #7
beabert
sudafed have that ingrediant in i think, so id say its your best bet.
Old 30-09-10, 04:38 PM   #8
Messie
The Teacer
Messie's Avatar
Sudefed works ok on the de-bunging factor. However IME gives you some very funny dreams!
Not sure if that's a good or a bad thing!
EDIT _ just remembered Sinutab. They always worked and fix the horrible headache bit too
Old 30-09-10, 04:51 PM   #9
Milky Bar Kid
Sudafed and Sinutab are both pretty good. Not had to use them for a while but both mum and dad have bother with their sinuses and think they are just as good as prescribed stuff
Old 30-09-10, 05:03 PM   #10
Bri w
Bri w's Avatar
Dettol and a wire brush.
Sudafed & S inutabs dry the mucus and can cause more problems the consensus amongst medics seems to be going away from drying the cr@p up. Olbas oil on your pillow, and a steroidal nasal spray to widen your tubes to allow them to drain easier + anti histamine tabs to reduce the irritation.
Or the Dettol remedy.
BBC Sport: Mental strength crucial for Smith NewsBot News 0 23-03-10 12:40 PM
Design and Strength Analysis Mr_Snips Bikes - Talk & Issues 7 20-02-08 12:43 PM
Any graphic/industrial designers? glade Idle Banter 6 30-10-06 10:05 PM
Quick Question about Chain Tensile Strength bigE SV Talk, Tuning & Tweaking 1 24-09-06 11:40 PM
