Old 07-10-10, 07:16 PM   #1
leebex
Default curvy rear brake slave cyl required.
Hi all, Im looking for a curvy rear brake slave cylinder, must be in working order please.
One of the mounting bolts has siezed big time on mine, and requires drilling out, and a helicoil, so thats a job for another day.
Thanks, Lee
Old 07-10-10, 10:26 PM   #2
Default Re: curvy rear brake slave cyl required.
FYI they are generally called caliper not slave cylinder
Old 07-10-10, 11:54 PM   #3
husky03
you needing a rear brake caliper?-£45 delivered just been serviced ready to fit -NO BRAKE PADS
Old 08-10-10, 07:00 PM   #4
leebex
see here, the housing that bolt number 10 is going into, not a caliper tho surely???
http://fiche.ronayers.com/Index.cfm/...ASTER_CYLINDER
Old 08-10-10, 07:15 PM   #5
Lee, you're correct, it is the rear master cyclinder assembly you're looking for
Sorry, not one in my spares, but its a common part on other Suzuki's
http://www.google.co.uk/#sclient=psy...d0e28c5feefbb9
Old 08-10-10, 07:19 PM   #6
leebex
Thanks Richard, had a little look on ebay, couldnt find an sv one, but will look for others that fit,
Does K3 use the same unit?
Old 08-10-10, 07:21 PM   #7
If you post the part number and description in here, then you'll get one cheap enough, as its a common part?
http://www.bike-breakers.info/
Have you been to the breakers on Colchester Hythe, motorcycle recycle I think they're called
http://stores.ebay.co.uk/motorcycle-recycle1
Old 08-10-10, 07:22 PM   #8
Dave20046
Dave20046's Avatar
I have one , check my sig.
Old 08-10-10, 07:45 PM   #9
leebex
Hi dave, sorry in the meantime of this topic i found one on ebay from an `06 suzuki and matched upto mine.
Thanks for the offer though
Curvy rear sub-frame, Front Discs required Suskie Stuff Wanted 3 09-09-10 09:03 PM
Curvy brake lever & rear brake pedal Old Git Stuff Wanted 1 09-01-10 11:00 AM
Front & rear brake bolt torque settings required. svsk2 SV Talk, Tuning & Tweaking 2 02-05-09 04:13 PM
Rear brake disc for curvy andyb For Sale - SV's and SV related items 0 27-04-08 06:02 PM
Rear brake lever for curvy Paws Stuff Wanted 1 05-02-07 02:02 PM
