Old 14-10-10, 07:12 PM   #1
sv650s 04
Default Indicator mirror flashing too fast.
iv just fitted a pair of indicator mirrors to my sv using resisters and they are flashing like crazy. The resistor was pluged in on the positive side of the circuit. I know a little about electrics but not loads. Has anyone got any ideas?
Old 14-10-10, 07:30 PM   #2
Cymraeg_Atodeg
Default Re: problem with indicator mirror...
Same principle different application, but, works all the same
http://www.lunaraccents.com/LED-taillight-circuit.html
Old 14-10-10, 08:26 PM   #3
sv650s 04
can anyone put that into simple form? I got so confused it was unreal.
Old 14-10-10, 08:38 PM   #4
SoulKiss
SoulKiss's Avatar
Simple answer - ditch the resistors, get a new flasher relay.
Not that difficult to fit and wont just sit there making heat...
Old 14-10-10, 08:40 PM   #5
keith_d
keith_d's Avatar
The person who designed the indicator circuit decided to be clever, by making the relay flash faster if one of the bulbs has gone. So when the power consumption drops the indicator goes faster.
LED indicators consume almost no power, so the indicator relay thinks the bulb has gone and starts flashing like fury. Connect a resistor across the LED to waste some power and the indicator thinks you've got a working bulb and flashes normal rate.
Hope this helps,
Keith.
Old 14-10-10, 08:48 PM   #6
sv650s 04
when you say across Keith do you mean bridge between positive and negative? Or just have it on the positive side?
Old 15-10-10, 08:08 AM   #7
keith_d
keith_d's Avatar
Default Re: Indicator mirror flashing too fast.
The indicator connector has two wires coming from it.
Connect the +ve to the one end of the resistor and the +ve of the indicator
Connect the ground (usually black) to the other end of the resistor and the -ve of the indicator.
Keith.
Old 15-10-10, 10:42 AM   #8
sv650s 04
All done and dusted. Working a treat now thanks for the help
Indicators flashing too fast... Gnome SV Talk, Tuning & Tweaking 17 14-02-18 06:50 PM
Front Indicator not working, rear flashing fast along with dash RavenWire Bikes - Talk & Issues 7 17-05-10 11:14 AM
LED indicators flashing fast. SuzukiNess SV Talk, Tuning & Tweaking 27 08-03-10 07:14 PM
Fast flashing indicators!! JimPSV SV Talk, Tuning & Tweaking 6 05-09-06 08:08 AM
LED indicator prob (and no it's not flashing too fast) brolong22 SV Talk, Tuning & Tweaking 5 05-07-05 11:11 AM
