Old 17-10-10, 07:27 PM   #1
stamasman
Default rear brake master cylinder upgrade, what fits?
want to upgrade my rear mastercylinder any1 know what would be a good option,what would fit etc.
Old 18-10-10, 09:14 AM   #2
flymo
flymo's Avatar
Default Re: rear brake master cylinder upgrade, what fits?
The stock SV master cylinder is more than up to the job
Old 18-10-10, 10:41 AM   #3
+1
if the brakes are feeling carp a quick clean and fresh fluid may cure it.
if not a master cylinder rebuild kit is less than £30 (for a curvy) on wemoto.com
Old 18-10-10, 10:45 AM   #4
Swin
Swin's Avatar
I found on my bandit that braided hoses improved the brakes no end, that's my project next spring with this bike
Swin is offline   Reply With Quote
Old 18-10-10, 10:57 AM   #5
barwel1992
i have to say my rear brake is rubbish, thats with new seals, braided hoses, HH pads, fresh fluid and no air in it at all
Old 18-10-10, 10:59 AM   #6
flymo
flymo's Avatar
I would doubt that bit, the SV rear brakes are good enough to lock the rear wheel into a buttock clenching slide when working properly
Old 18-10-10, 11:00 AM   #7
barwel1992
its been bled no end of times (off the bike) and i just cant get it to work, i can lock up easier using engine braking.
Old 18-10-10, 11:04 AM   #8
flymo
flymo's Avatar
assuming the pads are not glazed, not contaminated and have a good mating surface with the disc (not pressing against a banana shaped braking surface) then its almost certainly air in the system or something wrong with the MC seal/bore.
Old 18-10-10, 11:06 AM   #9
barwel1992
hmm, if its wet tomorrow i will strip it all down again and see whats hapening
Old 18-10-10, 11:19 AM   #10
No point doing it TBH
But if you want to there is neat one from CRF450 or something (IIRC) that fits, shiny with integrated reservoir.
I'm not 100% on this so you'd have to find one to check hole spacings and such.
rear master cylinder upgrade barwel1992 SV Talk, Tuning & Tweaking 27 27-12-09 03:41 PM
rear brake master cylinder kenada SV Talk, Tuning & Tweaking 5 20-09-08 01:20 PM
Rear brake master cylinder BillyC SV Talk, Tuning & Tweaking 1 16-07-08 12:46 AM
K2 rear brake master cylinder. ejohnh SV Talk, Tuning & Tweaking 5 06-12-06 02:09 PM
Rear Brake Master Cylinder jpb Stuff Wanted 1 16-06-06 10:05 AM
