Old 09-11-10, 10:52 AM   #1
MisterTommyH
MisterTommyH's Avatar
Default Changing gear lever, how easy?
to change my gear change lever?
I've got a new one off ebay - Is it simply remove spring clip, un-screw connecting rod, change lever, re-screw connecting rod, replace spring clip?
Or is there something more to it?
MisterTommyH is offline   Reply With Quote
Old 09-11-10, 11:06 AM   #2
Spikenipple
Spikenipple's Avatar
Default Re: How easy is it...
Yep that's about as complicated as it gets! Make note of the position of the linkage rod before undoing it so you can set the new one up the same.
Had: K7 SV650S in Candy Sonoma Red
Now: MT-09
My old SV
South & West Surfer
Spikenipple is offline   Reply With Quote
Old 09-11-10, 11:13 AM   #3
pretty much.
You need some split pins aswel and a bit Gen purpose grease doesn't go amiss
edit: just seen you sig and i'm not too sure on the split pins on a pointy
Old 09-11-10, 01:32 PM   #4
Scrawf
No on a pointy its a 'C' clip. Worth replacing this with a new one if you can.
Scrawf
Old 09-11-10, 02:04 PM   #5
MisterTommyH
Scrawf
Available from any good motorcycle outlet?
Old 09-11-10, 02:26 PM   #6
and halfrods
Old 09-11-10, 02:42 PM   #7
Scrawf
And eBay
Old 09-11-10, 05:30 PM   #8
MisterTommyH
Default Re: Changing gear lever, how easy?
Aaaaawwww.... now my first post doesn't make any sense!
Old 09-11-10, 07:54 PM   #9
Spikenipple
There's not really much point replacing the circlip unless it's completely shagged, which it shouldn't be. If it's marked or rusty just rub it down with a bit of emery paper or scotchbrite, regrease and reuse.
Now: MT-09
My old SV
South & West Surfer
Old 09-11-10, 08:01 PM   #10
MisterTommyH
Or if it flies off when I prise it off?
Bound to happen - anyone know what size?
Changing gear lever and rod Dave20046 SV Talk, Tuning & Tweaking 12 02-01-09 11:57 AM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
Changing Gear Lever Crammy15b SV Talk, Tuning & Tweaking 3 05-05-08 12:35 AM
Gear lever changing Renton SV Talk, Tuning & Tweaking 3 11-11-07 04:18 PM
Changing rear shock.... How easy/hard Iansv SV Talk, Tuning & Tweaking 32 29-05-06 07:15 PM
