Old 18-12-10, 08:40 PM   #1
barwel1992
Default bearings - reconditioning
Hi could some one recomend a good way to clean and grease 'sealed' type bearings i have in my rear sets ps i can get the outer covers off so can get to the bearings but cant take the balls out
i tired blasting the old grease out with WD40 then letting them dry, then i use lithium grease and they are still rough and not smooth like the (new) other rearset bearings :/
the bearings them selves look ok but they are so small i cant really see
they looke like a strange size, so will try and mutilate the old leaver and get both of them out to see if i can get new ones but they look machined down (ps GB moto charge £6 each so £12 per leaver and that a bit expensive for me atm)
any advice would be good ta
Old 18-12-10, 09:26 PM   #2
SVMAT
Default Re: bearings - reconditioning
Personally i would just replace, you can get them for penies online, i just use my local bearing place normally a couple of quid each. The size or code should be on the bearing. As for cleaning and regreasing id use some kind of solvent or even white spirit let them soak then blow them out with an air line if you have access to one.
Old 18-12-10, 09:28 PM   #3
barwel1992
cheers will go any have a ganders(look)
Old 18-12-10, 09:39 PM   #4
TSM
The Sick Man
TSM's Avatar
give this co a try
http://www.marksman-ind.com/
get the ID, OD and thickness of bearing and they can try and match up somthing
Old 18-12-10, 09:58 PM   #5
barwel1992
f608z ..... every skate bearing in the book comes up but taken one out and its not the same, it has a 25mm dia collar which is what makes it strange
so its 22mm OD
7mm depth over all ic collar (or width what ever it is lol)
7.8mm ID (where the shank of the bolt passes through)
25mm od collar (1.5mm thick)
:/ strange lol
Old 18-12-10, 10:09 PM   #6
barwel1992
LINK
Bingo think i got them, at the bottom of the page
Old 20-12-10, 04:18 PM   #7
barwel1992
cheapest i can get is £5.50 each at least they are SS though and wont rust
Old 20-12-10, 06:30 PM   #8
If they are rough when you have cleaned old grease out and repacked then they are toast.
Glad you found some new ones, I loaded mine up with heavy grease as soon as I got my GBmoto-alike ones.
Old 20-12-10, 06:43 PM   #9
barwel1992
so when i get the new ones should i just pack them with lithium grease
Old 20-12-10, 07:03 PM   #10
danf1234
Don't bearings come ready greased? My RGV wheel bearings certainly did.
head bearings coolbreeze Stuff Wanted 1 26-01-10 01:44 AM
Bearings Wideboy Bikes - Talk & Issues 6 08-12-09 09:18 PM
fork reconditioning Bibio Bikes - Talk & Issues 14 29-03-09 10:43 PM
bearings sv_rory SV Talk, Tuning & Tweaking 5 12-02-09 07:29 PM
Wheels and Bearings lawson17 SV Talk, Tuning & Tweaking 9 22-10-07 06:25 AM
