Old 31-12-10, 08:17 PM   #1
MrMessy
Default Rectifier Wiring Colours?
Does anybody know the wiring colours from the Suzuki rectifiers that have the grey wiring ie which 3 are the alternator wire(yellow on early models) and which are the positive and negative. I am considering useing a late model rectifier on my 99 SV.
MrMessy is offline   Reply With Quote
Old 31-12-10, 09:02 PM   #2
Default Re: Rectifier Wiring Colours:
The wiring colours have changed a few times - what colours do you have?
Alternator wires will ordinarily be three the same colour.
Old 31-12-10, 09:16 PM   #3
MrMessy
Default Re: Rectifier Wiring Colours?
Have not got one yet. Did not realise they had altered so many times. Mainly concerned with pos and neg ones. Do not want to mix them up! Thanks for you reply.
Old 31-12-10, 09:44 PM   #4
zadar
Alternators are 3 yellow on all sv's. Red is positive and black negative.
Old 10-01-11, 09:29 PM   #5
MrMessy
The rectifier has 3 black wires into a plug with normal sized spade connections. 2 black with white trace +2 black with red trace into a plug with pin connections. (3black = 3 yellow, black white negative? black red positive?)
Can anybody confirm this? Late Suzuki's use these colour codes?
Old 10-01-11, 09:41 PM   #6
keith_d
keith_d's Avatar
I've got the Haynes book here. It shows:
* Three black from the alternator in one connector
* Two black/white both to ground
* Two black/red to the main fuse
Anyone with some real experience like to confirm this?
Keith.
Old 10-01-11, 09:44 PM   #7
zadar
3 solid black wires are from generator (same as yellow on curvy), 2 black/white are ground and two black/red are positive.
Old 11-01-11, 08:12 AM   #8
MrMessy
Thanks for your help.
Old 11-01-11, 08:45 PM   #9
Ruffy
Ruffy's Avatar
This would be my assumption, too. Did it work?
You could test for pos and neg by wiring up the three input wires but instead of connecting the others, just put a resistor between them and then check polarity with a multimeter whilst bike is running total loss.
Spannering the wife's SV650S K5 pointy in Black, and son's SV650 X curvy in Blue.
RIP SV650 X curvy, crashed and written off December 2019.
I'm (procrastinating about) fixing up an old Yamaha FZ600 to get myself fully back on the road.
Ruffy is offline   Reply With Quote
K6 colours???? quikstu Photos 4 03-06-06 08:31 PM
RSV colours Demonz Bikes - Talk & Issues 7 07-05-06 07:46 AM
colours 05/06???? nivara SV Talk, Tuning & Tweaking 8 21-11-05 09:34 AM
colours... jonnyb SV Talk, Tuning & Tweaking 3 12-07-05 10:55 AM
colours jaymz The Essex Lounge 1 01-06-05 09:37 AM
