Old 03-01-11, 11:37 PM   #1
stew
Default oil leak clutch?
Hi all
well the curvy sv wont start, see other post, think the fuel has water or something in it.
put it on a padock stand to sort it out.
left it for a couple of days went out there this morning and a puddle of oil was on the floor looks like its from the bottom of the clutch case/cover.
its a 99 sv650 curvy.
is this going to be a compleate pain the rear or is it a simple job.
guess ill change the oil and filters while im at it
thanks peeps
Old 03-01-11, 11:38 PM   #2
husky03
Default Re: oil leak clutch?
probably just be the gasket-wipe the engine and sprinkle talc around the seal area-you'll then be able to see where leaks coming from.
Old 04-01-11, 12:09 AM   #3
stew
good idear husky ill give it a go.
is it a pig to change?
Old 04-01-11, 12:25 AM   #4
zadar
Plastic covers warp from age and temperature. You can replace cover or surface back sealing side flat. Replacing o-ring will not fix it if cover is warped.
Old 04-01-11, 12:35 AM   #5
stew
this will either cost me pennies or pounds then.
i think its the engine cover. is this plastic?
Old 04-01-11, 01:06 AM   #6
TamSV
TamSV's Avatar
The circular clutch cover is plastic on the curvy.
Old 04-01-11, 01:19 AM   #7
stew
i think it might be coming from the on that the round on sits on
Old 04-01-11, 01:52 AM   #8
TamSV
TamSV's Avatar
Ah right, that one's metal. Hopefully you just need a new gasket. I'd whip it off and check the cover carefully for any damage. If it looks OK put it back with a new gasket - some might recommend using gasket sealant.
Be careful you don't overtighten the bolts when refitting - they don't need much.
Old 04-01-11, 10:26 AM   #9
Viney
With the bike on the side stand, remove the clutch cover. On the '99 models its seperate, so chould come off easy. Check that the gasket is in good condition and as said, the covers can warp so clean it up and put it on a proper flat surface like a kitchen worktop with a torch under it and see if there is any light escaping when pushed down. You may get a little light leakage but look for large gaps. If it looks ok,then put the cover back on making sure that the gasket is in there propery, then tighten up opposite bolts as you go. Dont over tighten the bolts, i think its something like 5ft/lb or something equally as light.
Old 04-01-11, 10:43 AM   #10
Geodude
Geodude's Avatar
I had clutch cover leak on my 99 and used this stuff from halfrauds http://www.halfords.com/webapp/wcs/s...egoryId_165691 and it cured it no problem
Clutch cover oil leak. olisak SV Talk, Tuning & Tweaking 18 18-03-10 04:21 PM
Clutch cover oil leak. dmandub SV Talk, Tuning & Tweaking 12 19-02-10 01:37 AM
clutch cover seal (oil leak) sv-smc SV Talk, Tuning & Tweaking 9 31-01-10 06:47 PM
The never ending clutch cover oil leak badger-666 SV Talk, Tuning & Tweaking 3 20-02-08 07:25 PM
Curvy SV650 clutch cover oil leak bugsy46 Bikes - Talk & Issues 1 06-04-07 11:28 PM
