Old 04-01-11, 02:10 PM   #1
vardypeeps
Default HID light modification SV650 04 questions.
Afternoon.
Just have a few questions about HID kits for pointy SV's
Is it normal for just one bulb to be fitted as it covers both dip and high beam?
Is it worth fitting 2 or will it melt the clear plastic cover?
Do I have to do to a specialist to find the correct wattage and fitting bulbs?
Thanks for your time, hope these are easy questions
Rob
Old 04-01-11, 02:12 PM   #2
Default Re: HID light modification SV650 04
Just fit them, they put out less heat than halogen.
You get a ballast and a H4 bulb, they come in main/dip flavour so just put them in, they work in the same way as stock really. They just have a relay to operate the solenoid to dip them (actual bulb shield moves to raise beam rather than having an extra filament)
Old 04-01-11, 02:19 PM   #3
vardypeeps
Ah right ok.
When you say ballast would this be in place of the bulb on the left side or should one be fitted? They seem to make a slight buzzing sound constantly (like a quiet fuel priming system when you turn the key) is this normal too?
Thanks for your help Chris.
Rob
Old 04-01-11, 02:21 PM   #4
No the ballast is the electronic control and transformer, they make a slight buzzing yes, more on start up. You mount this bit somewhere out of the way. Then the lamp/bulb/capsule fits in where the normal bulb does.
Some people use one HID one halogen, you can use a HID in both sides no problem. (I would)
Old 04-01-11, 02:25 PM   #5
vardypeeps
Ahh cool, I understand.
Might pop out when I've picked the bike up and get a fresh bulb then.
Thanks so much for your help mate.
Rob
Old 04-01-11, 03:44 PM   #6
vardypeeps
Default Re: HID light modification SV650 04 questions.
I thought I was done with these questions but I've got one more!
The HID kit which installed on the SV 650 that I'm getting seems to have a round light tube around the bulb which is powered by an LED and used as a side light, is this normal for these kits and is that easy enough to replace aswell?
Cheers,
Rob
Old 04-01-11, 04:16 PM   #7
No it's not normal, who knows... I've never seen one. Personally I wouldn't bother with chav stuff like that, just use normal sidelights.
Old 04-01-11, 04:19 PM   #8
vardypeeps
When they blow I'll just leave em then. :P
Fuel light questions. cringer Bikes - Talk & Issues 8 19-06-10 10:54 AM
Questions, questions - light bulbs and oil leaks. garynortheast SV Talk, Tuning & Tweaking 7 25-03-10 12:55 PM
rear light questions george650 SV Talk, Tuning & Tweaking 4 12-01-09 01:09 PM
07 SV650 Gas warning light questions chevycowboy250x SV Talk, Tuning & Tweaking 1 10-07-08 04:21 AM
few twin light questions??? ben650 SV Talk, Tuning & Tweaking 15 28-01-06 11:01 PM
