Old 09-01-11, 02:51 PM   #1
Scar_Maker
Default Heel plate options?
Hey all,
So i have just gotten an SV650S 2004, superb condition i may add. My problem is the previous owner stuck on some really bad quality carbon fibre stickers.
I wanted to get some decent looking heel plates, the problem is the ones i have seen don't look right at all, the right side is one large solid unit, however the one you can buy are tiny triangles, and the left side is again a solid unit, the ones you can buy are again, tiny triangles.
Any help would be greatly appreciated.
Old 09-01-11, 03:20 PM   #2
Speedy
Default Re: Heel plate options?
The standard footrest/heal-plates are all one unit.
Your only options are after-market rear-sets or some kind of covering, (vinyl/carbon etc), get them polished, or to paint/powdercoat them a colour of your choice.
Any pictures of what's already on there?
Old 09-01-11, 05:21 PM   #3
The Curvy has separate heel plates, the Pointy does not.
Old 10-01-11, 01:48 PM   #4
Mr EnDo
I want to cover my heal plates as they have worn down to bear metal
Old 10-01-11, 02:43 PM   #5
Perhaps your heal plates will get better.
Old 11-01-11, 11:12 AM   #6
Jayneflakes
Jayneflakes's Avatar
I stripped and polished my heel plates and they look lovely now. A friend has offered to mill them out if I wished, but I quite like them as they are now.
You can see that I also polished the Top yoke and gear and brake levers, well I was bored and had to do physio on my damaged shoulder. so polishing fitted the bill perfectly.
Jayne you're a Pussy Magnet
Old 11-01-11, 11:14 AM   #7
Mr EnDo
How did you strip them Jayne, did you strip the yoke as well?
Old 11-01-11, 11:24 AM   #8
Jayneflakes
I did it all by hand, I started by filing off the casting marks until they were smooth and then I set to with wet and dry paper. Started with some quite course and worked up to fine, I also used wire wool at times to take out scratches. Finally polishing was done with a polishing mop in a hand drill and polishing soap.
Heel plate getting mashed Nobbylad Bikes - Talk & Issues 22 26-07-08 08:42 PM
heel plate adw Stuff Wanted 5 22-06-07 12:49 PM
Righthand Heel Plate - for a pointy Stu Stuff Wanted 9 06-03-07 09:46 PM
heel plate mesh Quiff Wichard Photos 2 25-04-06 10:58 PM
Heel plate protectors? thor SV Talk, Tuning & Tweaking 24 05-05-05 03:18 PM
