Old 13-01-11, 06:03 PM   #1
g13unisol
Default Side stand hitting floor
Hi all still new to riding so this might seem silly to some.
I did a few track days on my sk9 last year and found that my side stand was hitting the floor, well the little pokey out bit about half way down you use to put it down. I just wanted to know do people just cut this bit off or get some kind if light weight replacement stand. I use the bike normally so removing the side stand is not an option.
Old 13-01-11, 06:54 PM   #2
TSM
The Sick Man
TSM's Avatar
Default Re: Side stand hitting floor
oil the stand and check the spring to see if its returning fully, the foot peg should ground out first then the sidestand, also check chain adjustment as if its too slack it may knock the side stand down somtimes
Old 13-01-11, 06:57 PM   #3
Nick_69
Nick_69's Avatar
I have never found that my side stand hits the ground coz my peg gets there first, also if your getting the side stand/ peg down u could move your body more and get the knee down
Was SV650S K9
Now GSXR 600 K9
Old 13-01-11, 06:59 PM   #4
g13unisol
Ive changed the foot pegs got gillies fitted so i bit higher than standard but will check spring. Not got my knee down yet, it is this years challenge once weather is better and i do some more track days.
Old 13-01-11, 07:02 PM   #5
TSM
The Sick Man
TSM's Avatar
the gillies is your issue, ive got some on my SV and it caused that problem till i replaced the side stand for a GSXR SRAD 600 one many years back, its shorter and does not have the annoying loop
Old 13-01-11, 07:07 PM   #6
g13unisol
will i struggle to get my knee down using these rear sets i have them on the lowest setting but could not do it last year. still learning and not talked to anyone with an sv.
Old 13-01-11, 07:12 PM   #7
TSM
The Sick Man
TSM's Avatar
if you are having a problem its body position not a problem with the bike at all, dont worry about getting your knee down as it does not make you faster, you actualy are looking to have the bike as much upright as you can to put the power down, you need to lean off the bike more
Old 13-01-11, 07:19 PM   #8
g13unisol
body position is my plan for this year not so much speed. shame no where does an sv track day only would be cool to get some riding tips and tricks. only been riding a year.
Old 13-01-11, 08:32 PM   #9
have a look in the racing and paddock section, theres been a few threads around track riding since the cold weather appeared
Old 13-01-11, 10:27 PM   #10
keith_d
keith_d's Avatar
One of my mates recommended taking the side stand off and putting the bike up on a paddock stand when you park it. Obviously, it helps you've got someone along to bung the stand under the bike.
In my case I'm so far from getting the pegs down it doesn't really matter.
Keith.
Anyone got a left side rear set and side stand? Dhayn Stuff Wanted 6 17-08-09 10:08 AM
Side Stand Giffer2 SV Talk, Tuning & Tweaking 3 23-06-07 07:38 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Shortening the side stand SONIC157 SV Talk, Tuning & Tweaking 1 26-07-05 11:55 AM
Side stand Tris SV Talk, Tuning & Tweaking 6 17-10-04 12:12 AM
