Old 14-01-11, 07:30 AM   #1
dazzadams
Default Down shift problems
Hi, my sv650 sk3 shifts up gears ok but when changing down
Won't select the next gear, if I give the lever a little tap
With my foot and try again it selects..! Any ideas guys..?
Candy blue k3.. Likes going up but not going down!
Old 14-01-11, 09:17 AM   #2
Default Re: Down shift problems
Does the lever move smoothly? A common problem is the pivot being a bit gunged up, try lubricating that first and see if that alters things.
Old 14-01-11, 09:53 AM   #3
dazzadams
The lever moves smoothly and goes down and stops but doesn't click like they
Do when going into gear, if I tap it with the side of
My foot it feels like it slots back into place and I can the
Select down 1 gear then have to repeat the process for each downward gear.
I will have a clean up tho but have sprayed liberal
Amounts of wd40 all over it
Many thanks.
Old 14-01-11, 11:23 AM   #4
Mr EnDo
Many thanks.
WD40 in one word NOOOOOOO use some thing like GT85 from Halfords, its got PTFE that helps stay on the parts you spary and keeps them from jamming, thats what I did when I had this problem. I find WD40 washes off too easy and also dries up quick.
Old 14-01-11, 12:11 PM   #5
barwel1992
WD40 also removes grease and other lubricants i use it only for cleaning parts not for lubing them
Old 14-01-11, 12:31 PM   #6
novocaine
detent spring has gone. easy repair but requires removal of the clutch basket.
Old 14-01-11, 01:04 PM   #7
SUPERSTARDJ01
Selector forks/pins? what-ever they are, or as everyone says give it a good clean and lube, I get it loads on my Zx6 through winter.
Old 14-01-11, 02:17 PM   #8
_Stretchie_
Large Member
_Stretchie_'s Avatar
If I were you I would make a list of all that is being offered above and then list them in order of easiest to check first and work your way through them.
Couple of questions:
- Where are you?
- You any good with / own any tools?
There could be local .orgers nearby willing to help out.
How to amuze an idiot:
Look right-> <-Look Left
Old 14-01-11, 02:39 PM   #9
dazzadams
Ok thanks guys for all your help I'll have a play this weekend
And let you know how it went.
Old 14-01-11, 07:01 PM   #10
I wonder who would think of doing that? Surely the gearbox should come out the clutch basket should be taken off as first checks.
sv shift lights, where to set them ? barwel1992 SV Talk, Tuning & Tweaking 20 19-10-10 11:45 AM
Night shift Ed Idle Banter 7 31-03-10 02:52 PM
For the night shift Ed Idle Banter 9 19-08-09 07:50 AM
Gear shift rod Sean_C SV Talk, Tuning & Tweaking 3 21-02-09 08:04 PM
Shift-I Shift Light phizog SV Talk, Tuning & Tweaking 11 09-07-08 12:18 AM
