the threads are fooked after to days drilling session so what size should i tap the lug to
considering it M8 now i was thinking m10 but that would only leave 3.5mm of material each side of the bolt, is that enough ? OD is 17mm id would be about 10mm (m10) or should i use a helicoil |
Helicoil it M8.
ok so thats the best way to go ?
Yes
are they m8 x1.25 ? or x 1 dont have the bolt atm to look at
metric coarse
cheers again
But think about it you are putting helicoil in, it doesn't matter what you use, tap and coil it 5/16UNF if you want so long as you use a bolt to match
#9 |
#10 |
I know I said bolt above, but I prefer studs, stronger for same engagement and easier to remove if they are seized
Tapping noise from engine. | speedycoi | SV Talk, Tuning & Tweaking | 7 | 22-09-10 08:03 AM |
Drilling + tapping swing arm | pmapp | SV Talk, Tuning & Tweaking | 6 | 03-03-09 09:46 PM |
Tapping noise | yorkie_chris | SV Talk, Tuning & Tweaking | 6 | 17-06-07 01:44 AM |
Engine Tapping Behind Clutch | Torn-Thorax | SV Talk, Tuning & Tweaking | 22 | 09-01-07 12:48 AM |
tapping when my bike got hot | fullstop102 | SV Talk, Tuning & Tweaking | 6 | 30-07-06 10:39 AM |
