Old 28-01-11, 05:57 PM   #1
warrenhewitt10
Default Brake caliper question.
In the process of changing the piston seals, behind both of the dust seals there is epic amounts of this white stuff, im not at all suprised they are sticking, and may have to consider doing the other caliper too if this one is like this....
Old 28-01-11, 06:00 PM   #2
rictus01
rictus01's Avatar
Default Re: Is this normal?
well it's normal for calipers that haven't been serviced in some time yes.
Old 28-01-11, 08:17 PM   #3
warrenhewitt10
thats alright, new seals are in now, its bled, brakes feel a shed load better! they like go off when you release the brake lever and everything. Thats probably the first time they have been touched in 8 years.
Bit of fluid around the bottom of the caliper, but i'm hoping that might just be a bit of excess from putting them in, as the pistons and seals were swimming in brake fluid. I shall check in the morning to see if theres more
Old 28-01-11, 10:04 PM   #4
TamSV
TamSV's Avatar
I assume that was dry humour? Please tell me you've done them all.
Old 28-01-11, 10:12 PM   #5
warrenhewitt10
its not humour actually, I wasn't aware they got into this sort of shape over use, I changed all 4 seals on one caliper as it was sticking, the other one is fine atm. I reckon I probably will change all the seals in the other and the rear quite soon. I was descusted at the state of it
Old 28-01-11, 10:38 PM   #6
ty_uk
You should feel a lot better now you been de-custed
Old 28-01-11, 10:40 PM   #7
TamSV
TamSV's Avatar
Fair do's. The other one won't be far away from the same state though. No point in doing one side and not the other if you want nice brakes. It's a bit like having half a w*nk.
Old 28-01-11, 10:45 PM   #8
warrenhewitt10
yeah I know what you mean, the difference is like night and day even changing one. Id say I will change it fairly soon definately. Now that ive done it once it will be much easier. I was going to get someone to do it for me but thought meh, Im good enough at this stuff ill have a go at it.
Old 28-01-11, 10:49 PM   #9
Just to check, did you clean the caliper or just replace the seals?
Old 28-01-11, 11:16 PM   #10
warrenhewitt10
cleaned them up to as clean as a 8 year old caliper would go. Took a lot of scraping and tooth brush rubbing lol. Replaced with brand new seals, coated in brake fluid before they went in, made sure they were sitting correctly, pistons cleaned untill near chrome,slotted them in, cleaned and re-greased the slides. Hopefully ive done alright
SV Racing Parts, GSXR Brake Caliper Adapter Brackets, & Galfer SS Brake Lines & Pads sv-racing-parts SV Talk, Tuning & Tweaking 42 15-09-11 10:27 PM
brake caliper mouldy SV Talk, Tuning & Tweaking 7 24-03-09 04:37 PM
Quick brake caliper question Needsy SV Talk, Tuning & Tweaking 8 18-03-08 08:38 PM
Brake caliper help!! Wee-Man SV Talk, Tuning & Tweaking 4 03-06-07 07:49 PM
rear brake caliper question. kwak zzr SV Talk, Tuning & Tweaking 10 08-05-06 10:35 PM
