Old 10-02-11, 04:47 PM   #1
davepreston
Default fork exchanging random question
could cagiva plant 125 forks work on the sv, im talking is there a fundamental differance/ safety issue with using 125 bits compared to say a 1000,
so for example if you could make them fit (not that youd want to) put honda cbr 125 forks on a cbr thou, or would the stresses involved make it dangerous,
i await the org outrage/slagging/dumdass responces, then if someone would answer in the end that would be lovely
cheers
a planet is about the same weight and height as a sv650
Old 10-02-11, 05:04 PM   #2
timwilky
timwilky's Avatar
Default Re: fork exchanging random question
Obvious question dave is what brakes would you intend to use, most 125s etc only have a single brake caliper.
Not Grumpy, opinionated.
Old 10-02-11, 05:58 PM   #3
davepreston
sv brakes and wheel plus yokes just getting an adapted axle
Old 10-02-11, 08:18 PM   #4
Don't bother mate they're sh*te. Damping in one leg spring in other, only bracket to fit one brake, no adjustment.
Old 10-02-11, 08:21 PM   #5
davepreston
well thats that then
cheers
Old 10-02-11, 08:24 PM   #6
There is a reason people fit GSXR forks, there's no point trying to shortcut cos the stock ones are a shortcut that works-ish without faffing.
Old 10-02-11, 08:43 PM   #7
davepreston
just trying to make use of that bag of bolts in the back lol
Old 10-02-11, 11:57 PM   #8
I'll give you a tenner for it and you can have a go on it when I've grafted an XT600 motor into it.
random x box 360 question etuna Idle Banter 13 01-11-08 08:46 AM
Random question for the IT bods... Baph Idle Banter 6 23-10-08 09:30 PM
Random Can Weight Question G Bikes - Talk & Issues 5 09-04-08 06:40 PM
part exchanging wow Bikes - Talk & Issues 8 19-01-08 12:05 AM
Just a random question ljharmitt Idle Banter 23 21-01-07 07:28 PM
