Old 13-02-11, 06:08 PM   #1
garynortheast
garynortheast's Avatar
Default Scottoiler vacuum feed, where from?
Just about to get a Scottoiler to go on the SV. Could someone confirm (or otherwise) that T-ing into the vaccuum feed for the fuel tap will have no effect on the tap. I assume the tap will function normally as there will still be a vacuum there.
Old 13-02-11, 06:21 PM   #2
beabert
Default Re: Scottoiler vacuum feed
Ive seen others do that without issue
Old 13-02-11, 07:19 PM   #3
garynortheast
Excellent. Thanks for that.
Old 13-02-11, 08:41 PM   #4
Yes it's fine.
BTW the normal tee supplied is too small for the vacuum tubing used, you need something to fill in the gap, or a bigger tee.
Old 14-02-11, 07:24 AM   #5
garynortheast
Default Re: Scottoiler vacuum feed, where from?
This is a 2nd hand one Chris, originally bought for a Triumph so I'd been warned already that the t-piece is the wrong size. Thanks for the heads up anyway.
Old 14-02-11, 09:25 AM   #6
Nick_69
Nick_69's Avatar
If u need a new piece scootolier will send it to u for free
Was SV650S K9
Now GSXR 600 K9
Old 14-02-11, 08:40 PM   #7
garynortheast
Now that's handy to know - thanks for that Nick.
Old 20-02-11, 10:21 PM   #8
mep
mep's Avatar
Go to the Scottoiler website and download the installation guide. http://www.scottoiler.com/uk/installation-guides.html
Worked for me.
mep is offline   Reply With Quote
Old 21-02-11, 11:52 AM   #9
garynortheast
All fitted and done - carbs balanced too. The carbs were way out, it feels like a different bike now. It pulls cleanly from ludicrously low rpm and there's no more of the popping and f@rting from it on a steady throttle opening. I fitted the longer piece of hose to the front vacuum spigot to make balancing an easier job next time round.
Scottoiler is in place and I'll just need to spend a while adjusting the flow rate over the next few days.
Old 21-02-11, 12:18 PM   #10
Mr_Chin
Hi Gary
I'm glad you got it all sorted - did the bigger T connector fit then?
Denis
Scottoiler vacuum connection, reassurance needed. SVMAT SV Talk, Tuning & Tweaking 2 04-01-11 11:30 PM
Scottoiler - which vacuum hose noob-saibot SV Talk, Tuning & Tweaking 2 11-09-09 02:05 PM
engine vacuum for scottoiler. branny SV Talk, Tuning & Tweaking 9 14-07-05 08:45 PM
Feed me Better Red ones Idle Banter 16 08-03-05 12:03 PM
