Old 14-02-11, 09:45 PM   #1
svsam
svsam's Avatar
Default Mower starting trouble.
having trouble starting one of the mowers (not a bike i know).
never heard it run for more than 5 seconds, it'll start every now and again, but wont run for more than 5 seconds.
took the spark out and cleaned it, it was a bit oily, it does spark well (got a good shock off it).
also took the carb off it and gave it a real good clean, and checked the filters on the ends. the "diaphram" seems fine too.
still think it could be carb trouble, but i dont know what else to look for???
and help appreciated.
cheers,
sam.
SL0 jack up kit-yoshimura can-tial tidy-(so far)
svsam is offline   Reply With Quote
Old 14-02-11, 09:58 PM   #2
Default Re: Mower starting trouble.
had a mower do this and it needed a new plug. spark looked fine but the plug was kaput.
Old 14-02-11, 09:59 PM   #3
Sally
Push or ride-on?
Oil can get everywhere if tipped on their side!
Old 14-02-11, 10:17 PM   #4
Ed
Is there any contamination in the petrol?
Any crap in the fuel line?
Old 14-02-11, 10:19 PM   #5
Tried it at night? See if you can see any arcing. Is the plug wet when it dies? Does it restart straight away or need to cool down first (rich)?
Old 14-02-11, 11:11 PM   #6
embee
embee's Avatar
I'm with Bibio on this. I've had a couple of these.
One stumped me, it'd start and run fine, but if you stopped it, it wouldn't restart. Seemed like fuel problems so drained carb, blew out the jets etc, and it started again OK. Must have been fuel then? No. The plug cooled down and would start it again, but stop it and with a hot plug it wouldn't restart. Fitted a spare plug and it was perfect, so a new one went in.
Second one with similar symptoms I just fitted a new plug and all problems were solved.
Both of them sparked fine out of the engine.
I assume the fuel is reasonably fresh, that's the other simple fix come spring time after a winter lay-up.
Old 15-02-11, 08:00 AM   #7
mattSV
mattSV's Avatar
Mine used to be a bugger to start for the first cut of the year, and ran like a dog unless I replaced the fuel. Then it would start first pull, and ran sweet as a nut.
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 15-02-11, 10:21 AM   #8
Sally
Petrol does go off after a while!
Old 15-02-11, 05:23 PM   #9
Sir Trev
Sir Trev's Avatar
It's good practice to let petrol mowers run dry after the last cut of the year so you don't have any fuel going off in the tank/lines/carb. I forgot one year and it was a sod to start in the spring.
How long has your one been stood Sam?
Old 15-02-11, 10:10 PM   #10
svsam
svsam's Avatar
normally dont have a problem starting them, as we buy them as non runners.
the result: thank you and well done to all that suggested the simple spark plug, it started second pull an i have learnt something
trouble starting bluid SV Talk, Tuning & Tweaking 7 18-02-09 01:24 PM
Starting trouble gavinsky23 SV Talk, Tuning & Tweaking 6 18-03-08 08:07 PM
Trouble Starting andyharding SV Talk, Tuning & Tweaking 1 27-07-07 05:22 PM
Trouble Starting... jmoorse SV Talk, Tuning & Tweaking 3 04-10-06 04:55 PM
Trouble starting KUKKU SV Talk, Tuning & Tweaking 8 25-09-06 03:19 PM
