Old 17-02-11, 08:39 PM   #1
bigchris
Default Running rich?
Hi, all.
I'm in the process of re jetting my carbs and had a few questions.
Rode the bike today and here's what I found.
1. Bike seems to have lost torque and power .
2. Engine coughs when blipping throttle down gears. Backfires through exhaust also, but not every time.
3. Power loss seems worse after engine braking for any period
4. When cracking throttle open from idle, engine seems to hesitate. Not a lot but enough for me to notice.
5. The bike generally feels restricted.
Are these symptoms of running rich?
I'm thinking that after adding larger main jetts I may need to lift the tank and get a performance air filter to get more air in?
Any help apriciated. Cheers,
Old 17-02-11, 08:56 PM   #2
hardhat_harry
Default Re: Running rich?
Take spark plug out, does the anode look wet and sooty (too rich) or white (too lean)s a beige colour its ok.
Also check you have put all the pipes on the airbox including the blanking ones
Old 17-02-11, 09:04 PM   #3
hardhat_harry
Btw what mods have you made to make you think you need bigger jets?
Old 17-02-11, 09:12 PM   #4
bigchris
Fitted a Beowulf open can, the bike ran like crap after that.it was very lean. Was trying to cut out at low revs and would cough and die when blipping down gears. I could pull the choke on when the engine was warm and it would just rev out rather than cut out as expected, so I put 140 mains in and new 17.5 pilots, needle set at 2cd notch from blunt end & running standard air filter. Balanced the carbs and now it seems to have lost torque and power???
Old 17-02-11, 09:45 PM   #5
rictus01
rictus01's Avatar
sounds like you've mucked it up, fitting a can won't cause the symptoms you describe, so I'd guess you had another problem, and now all you've done is cover it with a further one.
lifting the tank will only increase the noise, and changine jets/ mucking about with neddles only makes sense with a free flow filter (something like a BMC RS) and a full exhaust system, anything short of that, leave the jets alone.
I'd suggest you return the carbs to standard, find the original problem, and take it from there.
Cheers Mark.
Old 17-02-11, 09:49 PM   #6
bigchris
Cheers Mark.
I may just do that, what could cause the probloms if it's not the jetting?
Old 17-02-11, 09:56 PM   #7
rictus01
rictus01's Avatar
I'd guess an air leak, but it's worth checking everything systematically rather than going for one thing to "hopefully" fix it, do a proper job and you don't have to guess.
Cheers Mark.
Old 17-02-11, 10:00 PM   #8
hardhat_harry
I think you need to go through a series of elimination.
Check plugs is it rich or lean?
Put standard jets in and the can you had before the Beowulf, is it still doing it?
Then you should know where to go from there but I suspect either airbox not fitted correctly, fuel line trapped, spark plugs or HT Leads not on properly
Old 17-02-11, 10:18 PM   #9
bigchris
Will check the plugs. I did put the original can back on and the probloms stopped? This what made me think the jetting was the problom. All the fuel lines were checked and the tap and pump. All fine. Thinking of just getting it to a dyno. I'm getting ready for scrapping it!!!
Old 17-02-11, 10:20 PM   #10
bigchris
Originally Posted by bigchris View Post
Will check the plugs. I did put the original can back on before i changed the jetts from standard and the probloms stopped? This what made me think the jetting was the problom. All the fuel lines were checked and the tap and pump. All fine. Thinking of just getting it to a dyno. I'm getting ready for scrapping it!!!
Running Rich Grant66 SV Talk, Tuning & Tweaking 3 14-02-10 08:15 PM
Running lean / rich sauluk SV Talk, Tuning & Tweaking 10 15-05-09 02:06 PM
Running rich AndyBrad SV Talk, Tuning & Tweaking 1 14-09-08 12:41 PM
im sure its running rich John 675 SV Talk, Tuning & Tweaking 11 03-10-07 01:21 PM
running rich? 01 sv650s SV Talk, Tuning & Tweaking 17 10-02-07 10:41 PM
