Old 06-03-11, 08:01 PM   #1
neio79
Default Advice required, Tow bar fitted, now Battery Flat
I had a towbar fitted on Friday with standard single electrics. Now this was done by a proper company rather than by myself so its not something i have done.
The problem is when i came to start the car this morning, nothing, flat as a pancake. Now this issue is only down to the fact the tow bar has been fitted.
Any one know what the issue could be, or had this happen to them with tow bar fitting.
The only thing i could think of was the fact i have the lights set to automatic, so maybe having that circuit open ready with the new wiring has caused a current drain somewhere?
I called the company and they said they will come out and re check the work, but in the mean time anyone have any ideas what could have caused this?
Oh BTW its a 2005 (mk 2) 2.0L TDCI ford focus.
Cheers.
Old 06-03-11, 08:05 PM   #2
punyXpress
punyXpress's Avatar
Default Re: Advice required, Tow bar fitted, now Battery Flat
Did they disconnect the battery ?
Now: Street Triple R
Old 06-03-11, 08:27 PM   #3
loose battery connection would be the first port of call.
Then the engine fuse tray
Old 07-03-11, 07:22 AM   #4
arenalife
Some towbar electric modules are powered from the cigarette lighter socket in the boot, maybe yours is always on rather than ignition switched (if it's anything like that at all). Can't see the drain flattening the batt though.
Old 07-03-11, 08:08 AM   #5
454697819
sounds like earth leakage?
Hope they fix it for you asap.
Flat battery - Advice please! StreetHawk SV Talk, Tuning & Tweaking 12 12-04-07 06:08 PM
flat battery x2 advice please hovis SV Talk, Tuning & Tweaking 16 21-09-06 10:48 PM
Flat battery cuffy SV Talk, Tuning & Tweaking 8 15-04-06 12:27 PM
flat battery-again! ronshaw SV Talk, Tuning & Tweaking 4 02-08-05 08:04 AM
