Old 08-03-11, 10:31 AM   #1
Luckypants
Luckypants's Avatar
Default Remove Sticky Residue
Not THAT sticky residue you pervs! Now I have your attention...
I put gaffa tape over the rear panels of the VFR to protect against scratches and the like while touring. She's being prepped for sale now and removing the gaffa tape has revealed a white powdery residue of the adhesive.
Any tips for removing this?
Old 08-03-11, 10:53 AM   #2
Default Re: Remove Sticky Residue
Steam clean?
Or Isopropl alchohol (wipe board cleaner) should do it.
I use it for cleaning DVD's with sticky stuff on them, (no not that kind of stuff )
Old 08-03-11, 11:04 AM   #3
Whyte25
Try WD40 - i use it to remove sticker residue / etc on my music gear. or Neat washing up liquid ( leave it to soak for a while)
Rgds
Old 08-03-11, 11:23 AM   #4
Steam clean?
or aftershave that you wouldn't ever wear.
Old 08-03-11, 11:30 AM   #5
Luckypants
Luckypants's Avatar
Can I get that from a stationers?
Old 08-03-11, 11:41 AM   #6
hongman
Hi Stickypants
Yeah any stationary shop should stock it.
Someone mentioned mayo works as well if left for 20mins or so?
Old 08-03-11, 12:15 PM   #7
tom-k6
i heard about the mayo thing, but think its just vinegar as active ingredient and the mayo helps it stick,
ive used lynx deodorant, not anti-perspirant, to get anything off anything. permanent marker/sticker bits/spray paint
Old 08-03-11, 01:34 PM   #8
600+
Carb cleaner, WD40, Alcohol, hot soappy water
any of the above will assist in removing residue.
The important question is what are you getting next?
Old 08-03-11, 01:56 PM   #9
Luckypants
Luckypants's Avatar
I already have this...
The silver viffer is making way for newer lower miles version in my favourite colour.
Old 08-03-11, 01:58 PM   #10
Viney
Wet n dry, or a 80 grit sanding disc.
How d'ya remove.... missyburd Idle Banter 27 27-10-08 01:04 AM
best way to remove carbs? Dave20046 SV Talk, Tuning & Tweaking 21 14-09-08 12:57 PM
Tyres...argh, sticky this sticky that :( ;) 21QUEST Bikes - Talk & Issues 33 01-06-07 08:55 AM
What's it for and can I remove it? mastiffmat SV Talk, Tuning & Tweaking 3 09-11-05 11:05 AM
Sorry old. Please REMOVE Richie Bikes - Talk & Issues 4 19-03-05 09:59 AM
