Old 12-03-11, 07:13 PM   #1
TheOnlyNemesis
Default 2001 GSXR 600 Indicator Problem
Hey guys and gals, got a little problem with my K1 GSXR-600.
Was riding today when the undertray fell down on one side, popped it back in and rode home, hoping the problem would be an easy fix.
Now my right indicators aren't working at all the front or the back, i checked the back to make sure the cables were still attached and everything looks fine, checked bulb in back and it not blown, I have checked the fuses and none of them are blown. I have looked to see if anything is shorting and i can't see anything.
The left indicators all work fine it is just the right indicators that won't flash at all, not even the front one but faster to say the circuit is broke, literally nothing happens when i try to indicate right.
Any ideas?
Old 12-03-11, 07:19 PM   #2
Default Re: 2001 GSXR 600 Indicator Problem
ey up stranger.
What part of the tray slipped, i'm thinking you've cut one the wires popping it up.
Also were you indicating at the time?
Old 12-03-11, 07:21 PM   #3
TheOnlyNemesis
Hey the whole right side slipped, the left side was held up by the bolt and i wasn't indicating i don't think, i've looked at all the cables and none attached to the indicator are ripped or anything.
Old 12-03-11, 07:24 PM   #4
barwel1992
checked all the other bulbs on that side ? if not test the relay (google)
Old 12-03-11, 07:40 PM   #5
TheOnlyNemesis
yeah, from looking at it, it looks fine
Old 12-03-11, 07:51 PM   #6
Holdup
Nut loose behind the bars
HTH
Old 12-03-11, 07:52 PM   #7
TheOnlyNemesis
**** you james XD
Old 12-03-11, 09:30 PM   #8
daved407
If all wires are ok try the front bulb thats not working. Sometimes a bulb out causes odd symptoms.
Old 14-03-11, 11:23 AM   #9
TheOnlyNemesis
Found a blown resistor that think might be it, the front indys are led but the rear ones are not, could a blown resistor stop only the right hand side from working?
Old 14-03-11, 06:55 PM   #10
monkey
Where is it in the wiring?
When you say blown do you mean it looks burned and melted?
Any other info?
Indicator problem. gabrielkeown SV Talk, Tuning & Tweaking 8 29-07-10 08:54 PM
2001 SV650S LHF Indicator and Bar end nipperju Stuff Wanted 2 13-03-10 11:33 AM
GSXR RHS indicator ibshort Stuff Wanted 2 30-08-09 09:19 PM
Indicator problem blackrat SV Talk, Tuning & Tweaking 6 08-09-08 05:28 PM
Indicator Problem Side MS SV Talk, Tuning & Tweaking 23 26-05-08 07:11 PM
