Old 24-03-11, 02:31 PM   #1
stew
Default what will a stage 3 jet do?
as above
seen a stage 3 dynojet kit for the sv.
what will it do?
what else will i need? ie k&n filter ect
will it go faster or go bang
Old 24-03-11, 02:41 PM   #2
johnnyrod
johnnyrod's Avatar
Default Re: what will a stage 3 jet do?
It's to be used in conjunction with a noisy can, better air filter, and a dyno. It'll be a selection of jets and other bits for the tuner to help optimise the carburetion more easily. It's not a bolt-on extra really. Doa search on here for tuning info, there's bucketloads. For a curvy, you really want the cam swap for VFM
Old 24-03-11, 02:45 PM   #3
stew
thanks jonnyrod
whats vfm?
the cam swap is that for the pointy cams?
its got a v.noisy can on it at the mo. and im looking into getting a better flowing air filter.
when i got the bike the guy i got it off said it had been stage 1 jetted and i got a recipt for it but no dyno print out.
Old 24-03-11, 02:55 PM   #4
johnnyrod
johnnyrod's Avatar
Value for money. Yep K3 cams on intake, and curvy intake cams swapped to the exhaust side. New jets without dyno work are useless, it's shooting in the dark. For the proper job you need a decent air filter (seem to be many opinions on these though) and get it on a dyno to have it set up. Adding the hot cams in this case won't need any rejetting, bit odd but that's the way it is. They don't cost a lot, around £150 I think, and if you fit yourself it's not too hard. The K3 intakes are already marked up the same, you just have to be careful setting the exhuast cam timing cos there aren't any useful marks on it.
Old 24-03-11, 04:18 PM   #5
hardhat_harry
I have the Cam swap and a full Akra system and its showing symptoms of lean running after the cam swap(banging on the overrun, dynoman says that lean as it burns the fuel slower, I thought it was rich that made the banging) So BMC airfilter only going on at dyno time. Must faster now though.
Old 24-03-11, 07:24 PM   #6
toxic
What size is the main jet for a stage 3 dynojet kit?
Stage 1 ,3 ect jet kits....stage 2? Torn-Thorax SV Talk, Tuning & Tweaking 11 05-03-07 07:36 PM
who has JHS stage 2 or factory pro stage 2? 01 sv650s SV Talk, Tuning & Tweaking 1 15-12-06 08:12 PM
Next stage after can? Carl SV Talk, Tuning & Tweaking 13 15-06-05 08:33 AM
JHS stage II cams for $200 Ziguy SV Talk, Tuning & Tweaking 75 19-03-05 05:18 PM
JHS Stage 3 Forks! 454697819 SV Talk, Tuning & Tweaking 2 14-10-04 11:59 AM
