Old 02-04-11, 01:00 AM   #1
monkey
Question Brakes juddering following complete service?
I recently had the brakes off my K5 GSXR 750 so gave them a complete service.
All went well and they're in very good nick but tonight on my first ride since doing them I was getting quite severe judder when coming to a stop from about 15mph.
I've read THIS recent thread all the way through and can't see how any of the suggestions could apply to me.
The only thing I can think of from the other thread is that I possibly didn't torque the steering stem nut properly as I also had the top yoke off to fit raised clip ons but I can't see me forgetting that. Also I didn't put any more copper slip on the back of the pads before I refitted them as there was already a bit on them.
Any suggestions?
Old 02-04-11, 01:19 AM   #2
monkey
Default Re: Brakes juddering following complete service?! Wtf?
Tell a lie, I fitted braided lines too as I needed a longer one.
Old 02-04-11, 07:00 AM   #3
G
One of the reasons I got rid of my 600rr was complete lack of confidence in the front brakes. I never could confirm what it was.
Have you changed the pads?
6.67300 × 10-11 m3 kg-1 s-2
Old 02-04-11, 07:21 AM   #4
Berlin
Well the conclusion in that thread is that the rivets that hold the discs were stuck and cleaning them helped.
So give your rivets a good cleaning (the spring loaded circles that allow your brake discs to float on the disc mounts).
If it happened all of a sudden, thats likely to be what it is... unless you happened to lean on/drop, bend one whist fitting or removing the discs.
A good dose of brake cleaner should sort it out, concentrated on the rivets.
C
Old 02-04-11, 10:20 AM   #5
monkey
I didn't remove the discs and I can't see how they would suddenly stick. I will check them however.
Having read countless threads on Gixxerjunkies it appears to be a problem with several K4/K5 600s and 750s although I can't find any that it seems to have started after being worked on.
Curiouser and curiouser.
Complete Service in progress... :-P cbay SV Talk, Tuning & Tweaking 4 15-01-11 08:30 AM
Juddering? sookie Bikes - Talk & Issues 50 06-11-09 04:56 PM
Juddering steering! SV-net SV Talk, Tuning & Tweaking 2 01-08-09 10:10 PM
juddering under heavy breaking hovis Bikes - Talk & Issues 34 03-11-07 03:56 PM
Should Brakes be bled/fixed on a service. enzyme SV Talk, Tuning & Tweaking 4 14-04-05 09:58 AM
