Old 02-04-11, 10:06 PM   #1
nikon70
Default Carbon Can Co Exhaust - Baffle?
ok this baffle is pop-riveted in place...
if I remove this (for cleaning purposes only*) how does one put it back after cleaning??
don't say pop rivet it! i dont have any or the tools....
has anyone done this before??
*i might forget to put it back tho....
Old 02-04-11, 10:24 PM   #2
steve.w
Default Re: Carbon Can Co Exhaust - Baffle???
Hi
Drilled mine out you need a decent drill bit by the way. It can be refitted with a self tapper but you probably won't want to bother
Old 02-04-11, 10:31 PM   #3
Can't you just stick a nut and bolt in the hole if you want to put it back on?
Old 02-04-11, 10:55 PM   #4
nikon70
what size drill bit did you use?
Old 02-04-11, 11:18 PM   #5
steve.w
Started with a small bit that just fitted inside the rivet then went up a size to release it easy peasy just drill fairly slowly
Old 03-04-11, 12:08 AM   #6
nikon70
might do that tomorrow... urm i mean today... as long as it's not raining.
sounds too much like the stock pipe at the moment.
Old 03-04-11, 08:37 PM   #7
Mark_h
Mark_h's Avatar
I use a nice stainless steel nut and bolt with a spring washer holding mine in. Beware though, there are a bit tougher to get out than you may imagine. Once you've drilled the rivet, stick a broom handle into the baffle and give it a good wiggle to get it out. Do not be tempted to pull it out with pliers or grips as they make a right mess of the baffle and it'll not look good when you stick it back.
Minister for Sustainability
Old 04-04-11, 07:24 AM   #8
TC3
think i used a 4mm drill bit to pop rivet out. took mine out 5 years ago and the only time it ever went back in is mot time. was tough to get out and dosent slip back in all the way but if you make sure the can is nice and hot should go in better. i used a broom handle i think to knock it out from the other end the first time i removed it.
Exhaust Baffle Nick_69 SV Talk, Tuning & Tweaking 3 24-10-09 10:52 AM
baffle on my exhaust! chris8886 Exhausts 16 22-05-07 05:44 PM
Got my exhaust! Which bit is the baffle? Kinvig Bikes - Talk & Issues 14 04-09-06 07:13 PM
wolf carbon race can with removable baffle ben650 For Sale - SV's and SV related items 6 04-07-06 06:26 PM
Exhaust Baffle VR46 SV Talk, Tuning & Tweaking 10 09-03-06 09:53 PM
