Old 12-04-11, 08:03 PM   #1
muzikill
muzikill's Avatar
Default Cylinder head oil pockets?
As part of the rebuild it says and shows (unclearly) that you fill the 'cylinder head pockets' with oil before putting the covers on. I've posted some pics if anyone can shed some clearer light on where is should be putting oil & how much in case i do it wrong.
Is it the area where the shims are? - i wouldnt expect it be the area where the cylinder head bolts are!
Old 13-04-11, 06:49 AM   #2
Default Re: Cylinder head oil pockets?
The pockets are around the valve buckets, also pour some oil around the lobes of the camshafts.
Disconnect the ignition system and remove the plugs, turn the engine over with the starter in bursts until the oil pressure has built before first starting the engine.
Old 13-04-11, 09:14 AM   #3
muzikill
muzikill's Avatar
Got it, enough oil just to prime it and lubricate around the valve springs.
Cylinder head cleaning muzikill SV Talk, Tuning & Tweaking 0 27-03-11 09:30 AM
K4 Front Cylinder Head Sideshow#36 Stuff Wanted 2 13-08-07 08:12 PM
Front Cylinder Head Sideshow#36 SV Talk, Tuning & Tweaking 3 12-08-07 11:10 AM
Cylinder head bolts gc350 For Sale - SV's and SV related items 0 26-06-07 12:53 PM
03 650S Cylinder Head metallica155 SV Talk, Tuning & Tweaking 3 04-09-06 11:12 AM
